Somebody can help me to see this code has what problem
The first picture is i run in my computer and it will just stuck at AT.The second picture is the correct sample. I find this code from youtube(Muhammad Ansar).
Connections:
MPU6050_____UNO
VCC_________5v
GND_________GND
SCL_________PinA5
SDA_________PinA4
#include <Wire.h>
#include “I2Cdev.h”
#include <MPU6050.h>
#include <TinyGPS.h>
#include <SoftwareSerial.h>
unsigned long fix_age;
SoftwareSerial GSM(2,3);
TinyGPS gps;
void gpsdump(TinyGPS &gps);
bool feedgps();
void getGPS();
long lat, lon;
float LAT, LON;
char inchar; // Will hold the incoming character from the GSM shield
int in1 = A0;
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
long val;
int buz = 13;
int stop = 0;
char *phone_no = {
“0183176292”,
void setup(){
pinMode(in1, INPUT);
Wire.begin();
mpu.initialize();
pinMode(buz, OUTPUT);
GSM.begin(9600);
Serial.println(“Initializing…”);
initModule(“AT”,“OK”,1000);
initModule(“ATE1”,“OK”,1000);
initModule(“AT+CPIN?”,“READY”,1000);
initModule(“AT+CMGF=1”,“OK”,1000);
initModule(“AT+CNMI=2,2,0,0,0”,“OK”,1000);
Serial.println(“Initialized Successfully”);
GSM.print(“AT+CMGS=”");GSM.print(phone_no[1]);GSM.println(""\r\n");
GSM.println(“Welcome to Arduino Based Vehicle Accident Alert System using GPS, GSM, Shock Sensor and Accelerometer”);
delay(300);
GSM.write(byte(26));
delay(3000);
getGPS();
void loop(){
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
val = map(ay, -17000, 17000, 0, 100);
Serial.println(val);
if((digitalRead(in1) == LOW)||(val<30)){
digitalWrite(buz, HIGH);
sms();
digitalWrite(buz, LOW);
if(GSM.available() >0){inchar=GSM.read();
if(inchar==‘R’){inchar=GSM.read();
if(inchar==‘I’){inchar=GSM.read();
if(inchar==‘N’){inchar=GSM.read();
if(inchar==‘G’){
GSM.print(“ATH\r”);
getGPS();
GSM.println(“RING Reply”);
GSM.print(“http://maps.google.com/?q=loc:”);
GSM.print(LAT/1000000,7);
GSM.print(",");
GSM.println(LON/1000000,7);
delay(300);
delay(5000);
long lat, lon;
unsigned long fix_age, time, date, speed, course;
unsigned long chars;
unsigned short sentences, failed_checksum;
// retrieves +/- lat/long in 1000000ths of a degree
gps.get_position(&lat, &lon, &fix_age);
void sms(){
getGPS();
GSM.println(“Emergency…”);
GSM.print(",");
delay(300);
delay(5000);
void getGPS(){
bool newdata = false;
unsigned long start = millis();
// Every 1 seconds we print an update
while (millis() - start < 1000){
if (feedgps ()){
newdata = true;
if (newdata){
gpsdump(gps);
bool feedgps(){
while (Serial.available()){
if (gps.encode(Serial.read()))
return true;
return 0;
void gpsdump(TinyGPS &gps){
//byte month, day, hour, minute, second, hundredths;
gps.get_position(&lat, &lon);
LAT = lat;
LON = lon;
feedgps(); // If we don’t feed the gps during this long routine, we may drop characters and get checksum errors
void initModule(String cmd, char *res, int t){
while(1){
Serial.println(cmd);
GSM.println(cmd);
delay(100);
while(GSM.available()>0){
if(GSM.find(res)){
Serial.println(res);
delay(t);
return;
}else{Serial.println(“Error”);}}
delay(t);
