Arduino Project - Social distance detector
I am trying to make a social distance detector for a project of mine. There are many projects online about this, but none of them are the right ones. I’m trying to make a thing that attaches to a lanyard. My original plan was when a PIR sensor detected a human, it would trigger the ultrasonic sensor into measuring the distance between the lanyard and the human. The problem is, the PIR sensor was always displaying “high”, and after doing some research, a PIR sensor can be only stationary. I am wondering if there are other easy and cheap options other than PIR sensors that can detect humans accurately? Thanks!
did you see ultrasonic HC-sr04 sensor with 2cm to 400cm range and with 3mm accuracy?
this is enough?
datasheet
arduino project of this sensor
smsebna:
this is enough?
…but has to be pointing at the object you want to measure the distance to.
Are you talking about buying a more accurate alternative than PIR sensors?
