Arduino ps2 keyboard
Hello, I want to connect an old keyboard to my arduino using the library "PS2 Keyboard" but even the sample program does not work.
/*  PS2Keyboard library example
  PS2Keyboard now requries both pins specified for begin()
  keyboard.begin(data_pin, irq_pin);
  Valid irq pins:
     Arduino Uno:  2, 3
     Arduino Due:  All pins, except 13 (LED)
     Arduino Mega: 2, 3, 18, 19, 20, 21
     Teensy 2.0:   All pins, except 13 (LED)
     Teensy 2.0:   5, 6, 7, 8
     Teensy 1.0:   0, 1, 2, 3, 4, 6, 7, 16
     Teensy++ 2.0: 0, 1, 2, 3, 18, 19, 36, 37
     Teensy++ 1.0: 0, 1, 2, 3, 18, 19, 36, 37
     Sanguino:     2, 10, 11
  for more information you can read the original wiki in arduino.cc
  at http://www.arduino.cc/playground/Main/PS2Keyboard
  or http://www.pjrc.com/teensy/td_libs_PS2Keyboard.html
  Like the Original library and example this is under LGPL license.
  Modified by Cuninganreset@gmail.com on 2010-03-22
  Modified by Paul Stoffregen <paul@pjrc.com> June 2010
#include <PS2Keyboard.h>
const int DataPin = 8;
const int IRQpin =  3;
PS2Keyboard keyboard;
  keyboard.begin(DataPin, IRQpin);
  Serial.println("Keyboard Test:");
  if (keyboard.available()) {
    // read the next key
    char c = keyboard.read();
    // check for some of the special keys
    if (c == PS2_ENTER) {
    } else if (c == PS2_TAB) {
      Serial.print("[Tab]");
    } else if (c == PS2_ESC) {
      Serial.print("[ESC]");
    } else if (c == PS2_PAGEDOWN) {
      Serial.print("[PgDn]");
    } else if (c == PS2_PAGEUP) {
      Serial.print("[PgUp]");
    } else if (c == PS2_LEFTARROW) {
      Serial.print("[Left]");
    } else if (c == PS2_RIGHTARROW) {
      Serial.print("[Right]");
    } else if (c == PS2_UPARROW) {
      Serial.print("[Up]");
    } else if (c == PS2_DOWNARROW) {
      Serial.print("[Down]");
    } else if (c == PS2_DELETE) {
      Serial.print("[Del]");
      // otherwise, just print all normal characters
      Serial.print(c);
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Nobody will help?
Please read and follow the directions in the "How to get the best out of the forum" post.
I just wanted to do it
design:
https://www.instructables.com/Arduino-Basic-PC-With-TV-Output/
Unfortunately, not everything works properly, after connecting to the TV the image is displayed correctly. However, the keyboard doesn't want to work for anything. I will consume the same elements so I don't know what this may be due to. Everything is properly connected.
