My idea:
Taking still photos when triggered by a pulse rate sensor and saving it onto a SD card.
The device is to be worn on a dog.
First of all, is the arduino uno powerful enough for my application?
Any recommendations on the camera module to use? Something that takes decent picture.
PS: Trying to replicate something similar to this.
http://heartography.nikon-asia.com/#how-it-works
Would appreciate some inputs.
Thanks!
Measuring the pulse rate of a dog looks quite complicated to me. Do you already have an idea?
- First of all, is the arduino uno powerful enough for my application?
Well I would say no.
Arduino still image to SD card - 10 to 15 seconds with a jpeg encoded serial camera. And that is not doing anything else.
Measuring the pulse rate is hard enough on a person, so that is the weak spot of the project.
DrDiettrich:
Thanks for the inputs.
After more research, have decided to use the polar wireless heart rate senator with a receiver board instead. The transmitter would be worn around the neck of the neck.
Grumpy_Mike:
Thanks for your inputs!
Would using a more powerful arduino help? Eg better ram?
Or should I use some other boards such as the rasberry pi or Edison board?
Originally decided on the Uno due to its smaller form factor for use as a wearable. If the prototype worked, the plan was to use a lily pad/flora.
Yes but only the Yun would stand a chance of doing anything.
The Raspberry Pi could do it but it takes a lot of current for a mobile device. I have no experience with the Edison as my experience with the Galileo put me off Intel designed development boards.
