Arduino pulsein function missed pulses..
Hi guys, I dont know how it works for others. Really
Every time when I use this function, it misses pulses. I controled these missed pulses from relay's led.
In below program I tried to get pulse values from flowmeter with pulsein function.
For example I write 6 to serial monitor and programs swich on the relay. when i count 6 pulse from flowmeter, relay is swiched off and dosing finished.
Please help me, I m thinking suicide anymore. :)(
//eprom değişgenleri
const byte interruptPin = 2;
const byte rolePin = 3;
int incomingByte;
float toplampulse;
unsigned long duration;
// pinMode(interruptPin, INPUT);
 pinMode(rolePin, OUTPUT);
  pinMode(interruptPin, INPUT_PULLUP);
// the loop routine runs over and over again forever:
  digitalWrite(rolePin, LOW);
  toplampulse2=0;
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.parseFloat();
                // say what you got:
                Serial.print("I received: ");
                Serial.println(incomingByte, DEC);
toplampulse=0;
digitalWrite(rolePin, HIGH);
do{
//Serial.println(toplampulse);
  duration = pulseIn(interruptPin, HIGH,2000000);
  if(duration>200)
toplampulse++;
Serial.println(toplampulse, DEC);
Serial.println(duration, DEC);
 if((toplampulse-1)==incomingByte)
  Serial.println("Dozajlama Bitti.");
}while(digitalRead(rolePin)==HIGH);
Anyone can help me?
I'm still looking at your code. In the meantime, I've taken the opportunity to re-format it so it looks a bit more like what we're used to do perhaps others may see the issue more clearly...
int incomingByte;
float toplampulse;
    toplampulse2=0;
        toplampulse=0;
        do
            if(duration>200)
                toplampulse++;
This is an equality test between two floats. Almost never will they be the same. Think of testing the difference between the two being less than some threshold, i.e. a - b < .01.
pulseIn() is not a good function for detecting a pulse. Try treating your input as a button press using the example File->Examples->02.Digital->Debounce Your increment of the count would replace " ledState = !ledState;".
