jeiry
May 8, 2022, 2:40pm
1
I push a char into a char array in Arduino. Here is the code:
#define q_length 10
char * queue[q_length] = {"10","9","8","7","6","5","4","3","2","1"};
int in = 0;
char buf[60];
strcpy(buf, "--");
char ii[20];
itoa(in, ii, 10);
strcat(buf, ii);
for (byte i = q_length-1; i > 0; i--){
queue[i] = queue[i - 1];
queue[0] = buf;
in ++;
for (byte i = 0; i < q_length; i++) {
Serial.print(i);
Serial.print(":");
Serial.println(queue[i]);
Serial.println("==========");
and output
0:--0
1:10
2:9
3:8
4:7
5:6
6:5
7:4
8:3
9:2
0:--1
1:--1
2:10
3:9
4:8
5:7
6:6
7:5
8:4
9:3
0:--2
1:--2
2:--2
3:10
4:9
5:8
6:7
7:6
8:5
9:4
As you can see, every time I push a new one the other char I just pushed change became the new one.
I want to push the new char into the char array index 0, right shift the entire array, and just change the index 0 char. Not all of them.
J-M-L
May 8, 2022, 2:44pm
2
jeiry:
queue[0] = buf;
You assign the pointer to that location… you don’t copy the content over, so…
jeiry
May 8, 2022, 3:00pm
3
I try strcpy
for (byte i = q_length - 1; i > 0; i--) {
strcpy(queue[i], queue[i - 1]);
strcpy(queue[0], buf);
output:
could you tell me how to do please.
J-M-L
May 8, 2022, 3:02pm
4
Strcpy would require memory to store the string at the destination… you only declared an array of pointers
If you had a 2D array that could work (as long as you don’t overflow the memory allocated for each string)
This is your code with some changers and deletions.
I have no idea what you are trying to do, but this makes nice output
# define q_lenth 10
// bzzzt! THX @J-M-L char queue[q_lenth] = {'10','9','8','7','6','5','4','3','2','1'};
char queue[q_lenth] = {'9','8','7','6','5','4','3','2','1','0',};
unsigned char temp = queue[q_lenth - 1];
for (byte i = q_lenth-1; i > 0; i--){
queue[0] = temp;
for (byte i = 0; i < q_lenth; i++) {
Serial.print(i);
Serial.print(":");
Put your finger on the code and see how it works. Put your finger on your code and see why it doesn't.
Look at the differences between the two. Tray to figure out what the differences mean.
a7
J-M-L
May 8, 2022, 3:17pm
6
alto777:
'10' does not fit in a char....
No, no it doesn't. I'll leave it to later to see why I still got OK output.
Replace '10' with '0'.
a7
jeiry
May 8, 2022, 3:22pm
8
thanks for your replay.I'm trying to make a queue.I got too many data from a sensor in a moment. then sent the data through a lora by ttl. interval 500ms. so I need a queue send them one by one. I read you code. It juse makes a nice output.
jeiry:
It's easier to use logic than to do all that shuffling.
Look into "ring buffers" or "circular buffers".
Easier and if it is ever important, faster.
a7
For future reference, this is a recipe for disaster. buf needs to be a nul-terminated character array. Either use memset() to initialise it or use
char buf[60];
buf[0] = '\0';
strcpy(buf, "--");
J-M-L
May 8, 2022, 5:22pm
12
no...
strcat would but strcpy will happily overwrite whatever is there and write the trailing null char
J-M-L:
no
Time to go to bed for me.
J-M-L
May 8, 2022, 5:37pm
14
coffee or a walk outside works too
I'm having coffee and sitting outside (having a smoke).
J-M-L
May 8, 2022, 5:46pm
16
I'm sure that was the smoke then... bad habit !
system
Closed
November 4, 2022, 5:47pm
17
