Arduino push button Double Click function
Hello Folks,
It took me some time to do the following script for a simple Double Click function that suits my needs and I would like to share the following codes with you.
Am using one button to turn ON/OFF, 2 LED.
// set PushButton pin number
const int buttonPin = 2;
// set LED pin numbers
const int LED1 = 8;
const int LED2 = 9;
// set LED pin 13
const int LEDP13 = 13;
//initialising led
int LED1Status = LOW;
int LED2Status = LOW;
int buttonState;
unsigned long timePress = 0;
unsigned long timePressLimit = 0;
int clicks = 0;
  // initialize the LED pin as an output:
  pinMode(buttonPin ,INPUT);
  // initialize the pushbutton pin as an input:
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH){
    delay(200);
    //Serial.println("Button Pressed");
    if (clicks == 0) {
    timePress = millis();
    timePressLimit = timePress + 1000;
    clicks = 1;
    else if (clicks == 1 && millis() < timePressLimit){
      Serial.println("Button Pressed twice");
     //Double Press Action
     if (LED2Status == LOW){
      digitalWrite(LED2, HIGH);
      LED2Status = HIGH;
     else if (LED2Status == HIGH){
      digitalWrite(LED2, LOW);
      LED2Status = LOW;
     //set variables back to 0
      timePress = 0;
      timePressLimit = 0;
      clicks = 0;
  if (clicks == 1 && timePressLimit != 0 && millis() > timePressLimit){
     Serial.println("Button Pressed Once");
     timePress = 0;
     timePressLimit = 0;
     clicks = 0;
     if (LED1Status == LOW){
      digitalWrite(LED1, HIGH);
      LED1Status = HIGH;
     else if (LED1Status == HIGH){
      digitalWrite(LED1, LOW);
      LED1Status = LOW;
Can you update your code to support 6 way like this:
  1. Single Click (click one time)
  2. Longpress (Single Click and Hold)
  3. Double Click (click two times)
  4. Double Click and hold (that mean 1 click and then LongPress)
  5. Trible Click (click three times)
  6. Trible Click and hold (that mean double click then Longpress)
Bonjour j aimerais faire un double click simple pour allumer une led
Je suis débutant et je n arrive pas à trouvé le code,
Pourriez vous m'aidé
Merci.
