I would guess that the 3v Hitec signal spec is refering to the minimum voltage that the input signal needs to be. I don't know what the signal output voltage peaks are for the R/C receivers they are normally used with. I do know that the Hitec servos work quite well with 5v signals supplied from various servo controllers. The person requesting the info really needs to contact Hitec to get the qualified answer. Any answers here will probably be speculation.
Nothing about 3v that I can see. It gives specs for operating at 4.8v and 6.0v, and every Hitec servo (a hundred or so of many different models) that I have used uses a signal voltage at the same as the power voltage.
Hook it up to your output pin. Power it from a separate source and tie the ground to the Arduino ground.
Use the servo library to attach the logical servo to the same pin that the physical servo is attached to.
Watch your servo move to the command of the Arduino.
Wow, what a action! Sorry, but i whas not connected for a few days.
All thanks for answers.
Here we go:
@zoomkat
Yes, after a search and few tests i have moved to the software section.
But your right i have not explained properly, this 3V PWM signal will be the minimum.
@retrolefty
software:
"standard firmata" with Maxuino 009 Max patch.
But this i post this better in the software section, i think?
hardware:
servo to Arduino connection:
AC to 6V DC 2000mA powersupply -> negative lead (black) -> Arduino ground
Servo black wires -> Arduino ground
Servo Red wires -> AC to 6V DC 2000mA powersupply positive lead (red)
Servo yellow wires -> servo signal pins (Arduino digital pins 9 & 10)
I think so, but is this ok?
@vinceherman
The technical service from Hitec has send me a mail to say that it has to be 3V PWM signal.
But like zoomkat says, it will be the minimum.
