Arduino PWM lag Serial
Code:
int inSerial;
TCCR2B = TCCR2B & B11111000 | B00000101;
while (Serial.available()==0){}
inSerial = Serial.parseInt();
analogWrite(3, inSerial);
Serial.println(inSerial);
When I send for example 127 ( 50% duty cycle ) through the serial monitor, the change is applied after about 1 second. No matter what hardware clock I use (which PWM pin), frequency or serial speed - the lag still exist.
Thanks in advance.
parseInt timeout is. . . ?
Serial monitor line-ending is . . ?
is it the print or the voltage that lags?
why not
if (Serial.available())  {
i'm not sure if available() indicates a complete line has been received of just the next byte.
gciurpita:
why not
You could check the documentation. It’s pretty clear.
or ask the airplane
airplane? What?
TheMemberFormerlyKnownAsAWOL:
parseInt timeout - not defined
Serial monitor line-ending - No line ending
The idea is to be able to change duty cycle through serial communication (in this case, the serial monitor) and keep it until I change it again whenever I want. I probably need to use another technique to convert information through serial communication to integer.
I will be grateful for the examples.
as “themember…” said, parseint() accepts all characters up until the first non-digit. hence a timeout. you might try appending a non-digit to see what happens.
airplane? What?
execute the action on the airplane to see what it does … try it out
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
See this:
