Arduino - Python : Read data
Hello,
I do a prototype of checkers board with a teensy++ 2.0, I use reed switch to detect the move of pieces.
With the IDE Arduino, I have no problem to display exactly what I want(in red in the Arduino code), so the move like "33-28 ".
But when I use a python script, nothing appears in my Terminal.
I tried to display more data than my move. And in this case, the display is not in live, because I need to move another piece to display the move previous, but something is display.
So I don't understand how to get data in live and how just get my move.
Here is my simplified code :
Arduino :
#define rows 10 // define number of rows
#define columns 10 //define number of columns
int rowpins[rows] = {0,1,10,11,12,13,14,15,16,17} ;
int columnpins[columns] = {45,44,43,42,41,40,39,38,20,21} ;
int currentState[rows][columns]; // array for current state during pick
int previousState[rows][columns]; // array for comparing state during pick
int reading[rows][columns]; // array for pin read value
int damier[rows][columns] = {{0},{0}};
int turnColor; // 0=White 1=Black
String move;
int moveOk;
int colorPlayer;
int longueur=0;
int nb_rafle=0;
unsigned long debounceDelay = 50;
unsigned long lastDebounceTime[rows][columns]; // array for saving debounce times
enum{VIDE,B,N,DB,DN};
const String positionArray [rows][columns] = {{"", "1", "", "2", "", "3", "", "4", "", "5"},
                                            {"6", "", "7", "", "8", "", "9", "", "10", ""},
                                            {"", "11", "", "12", "", "13", "", "14", "", "15"},
                                            {"16", "", "17", "", "18", "", "19", "", "20", ""},
                                            {"", "21", "", "22", "", "23", "", "24", "", "25"},
                                            {"26", "", "27", "", "28", "", "29", "", "30", ""},
                                            {"", "31", "", "32", "", "33", "", "34", "", "35"},
                                            {"36", "", "37", "", "38", "", "39", "", "40", ""},
                                            {"", "41", "", "42", "", "43", "", "44", "", "45"},
                                            {"46", "", "47", "", "48", "", "49", "", "50", ""}}; // set array position names
int colorArray [10][10]={{0},{0}};
typedef struct Direc Direc;
struct Direc{
  int i,j;
int cases=0;
int max_longueur=0;
int max_cases=0;
  Serial.begin (9600); // Start serial comms
  //delay (2000);
  initialise (); // initialise function
  //Serial.print("Hello");
  searchMove();
  moveVerification();
void initialise () {
  [color=limegreen]Serial.write ("Board initialising");[/color]
  for (int i = 0; i < rows; i++) { // Set rows to LOW INPUT
    pinMode (rowpins[i], INPUT);
    digitalWrite (rowpins[i], LOW);
  for (int j = 0; j < columns; j++) { // set columns to INPUT with PULLUP
    pinMode (columnpins[j], INPUT);
    digitalWrite (columnpins[j], HIGH);
    pinMode (rowpins[i], OUTPUT); // set row to LOW OUTPUT
    reading[i][j] = digitalRead (columnpins[j]); // read board positions and set for initialise
    currentState[i][j] = reading[i][j];
    previousState[i][j] = reading[i][j];
    pinMode (rowpins[i], INPUT); // set row back to INPUT
  [color=limegreen]Serial.println (" ");
  Serial.println ("Current Layout:");
  Serial.println (" ");[/color]
  for (int a = 0; a < rows; a++) {
    for (int b = 0; b < columns; b++) {
      if (reading[a][b] == 0) {
        if (a < 4) {
          colorArray[a][b] = N;
        } else if (a > 5) {
          colorArray[a][b] = B;
          colorArray[a][b] = VIDE;
  colorPlayer = B;
void setCases(int a){
    cases=a;
int getCases(){
    return cases;
int findMove(int i, int j, int colorPlayer) {
  /*Search all enables moves*/
int findMoveDame(int i, int j, int colorPlayer) {
 /*Search all enables moves for draughts*/
int trouver_rafle(int i, int j, int carte[][10],int longueur){
   /*Search the biggest path with piece*/
int trouver_rafle_dame(int i, int j, int carte[][10],int longueur){
    /*Search the biggest path with draughts*/
void searchMove() {
  /*Search if the piece played is a good move*/
void moveVerification() {
 if (moveOk == 1) {
  [color=red]Serial.print(move);
  Serial.print(" ");[/color]
  moveOk = 0;
  setCases(0);
  longueur = 0;
  max_longueur=0;
  max_cases=0;
  nb_rafle=0;
  if (colorPlayer == B) {
    colorPlayer = N;
    colorPlayer = B;
Python :
import serial
serial_port = '/dev/cu.usbmodem12341';
baud_rate = 9600; #In arduino, Serial.begin(baud_rate)
write_to_file_path = "test2.pdn";
output_file = open(write_to_file_path, "w+");
ser = serial.Serial(serial_port, baud_rate)
while True:
    print("test");
    line = ser.readline();
    line = line.decode("utf-8") #ser.readline returns a binary, convert to string
    print(line);
    output_file.write(line);
Thanks a lot for your help.
Quentin
Have a look at this Python - Arduino demo
It may need a little modification if you are using Python 3 as it was written with 2.7
...R
What did the compiler think of that crap?
Robin2:
...R
Thanks Robin2, I will try to adapt it to my project.
PaulS:
It's a mistake ... it was a test and I forgot to replace by printf.
Robin2, thanks a lot !
I can get my move !
