Arduino R3 chip with Bluetooth connection
I am participating in a science competition at my high school and I would like to bring this project for my presentation.
Firstly, I will connect the Air Quality Sensor MQ-135 ()with the chip and then connect the chip to my computer in order to import the code running MQ-135 from my computer to the chip using the traditional way. Like in this Video: How to connect MQ 135 With Arduino and Code ||ARDUINO WITH MQ135 - YouTube
Secondly, I will disconnect the chip from my computer and then power it with external sources such as a battery because of mobility. Then, I connect them with the HC-05 BlueTooth module
Finally, I create an app on AppInventor to demonstrate the data collected by the sensor with the connect of BlueTooth module
Please guy, I really need your help.
Start by writing a sketch that reads the sensor attached to the Arduino and displays the data on the Serial monitor
if you wish to add mobility rather than using an Arduino R3 + HC-05 use an ESP32 which has built in Bluetooth Classic, BLE and WiFi
have a look at air-quality-sensor-mq135-cloud-mqtt
Do the ESP32 work with external sources such as battery bro?
Yes, of course it does
do a web search for esp32 battery support you will get plenty of links
