For the past couple of days I have been trying to turn on a SK6812 RGBW LED with my new Arduino R4 Wifi board and after trying around 10 different codes with the Adafruit NeoPixel library (even the example ones) and other libraries I don’t understand why the LED doesn’t work. If I apply current from the 5v pin to the data pin it turns on, so the LED isn’t broken and the soldering is fine, also the test code to turn the internal 13th LED pin works (the internal LED Matrix too) but still no light on the SK.
All numerical pins have 2.5v on idle powered through USB. The pin 13 gets 5vs if a jack is connected and the pin open with this test code, still no light. Capacitor or resistance doesn’t make any difference.
I have tried absolutely everything I imagined and found on internet for hours, if you guys know a solution I’ll be blessed.
Here is the code I'm using at the moment to make tests:
#include <arduino.h>
#define LED_PIN 13
#define LED_COUNT 1
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_RGBW + NEO_KHZ800);
pinMode(13, OUTPUT);
strip.begin();
strip.setPixelColor(0, 255, 0, 0, 50);
digitalWrite(13, HIGH); // set the LED on
delay(2000); // wait for a second
digitalWrite(13, LOW); // set the LED off
delay(2000);
digitalWrite(6, HIGH); // set the LED on
digitalWrite(6, LOW); // set the LED off
delay(2000);
strip.show();
