When using the demo code for the library, you need to make a change for it to work with the Arduino R4. The header file (PRDC_7193.h) will throw errors on compile because PIN_SPI_SS is defined for the R3, but not for the R4. The R4 uses PIN_SPI_CS You will get an error of:
error: 'PIN_SPI_SS' was not declared in this scope
To solve this, you replace this line of code:
#define AD7193_DEFAULT_CS PIN_SPI_SS
with these lines which will let it compile for either the R4 or the R3 Arduinos:
#if defined(PIN_SPI_SS)
#else
#define AD7193_DEFAULT_CS PIN_SPI_CS
#endif
The person who solved this for me was van_der_Decken on this forum. I am only posting this to document the problem/solution. I don't need a reply.
