I want to build a simple arduino radio project with related programming.
The only thing it has to do is to start playing the radio at a specific time during the day, for a specific amount of hours and then stop. I am going to use it as a wake-up-clock radio.
My question is, how do i build it and how do i setup the programming?
Assume you would be buying or using an existing radio..??
In which case you would be building a "timer" and if not connected to a PC then include a decent real time clock module (DS3231)
Plug in power supply, possibly a 5V single channel relay for Arduino, promini or nano, jumper leads, soldering gear, maybe a breadboard for initial setup testing.
Put together a prototype schematic showing all connections etc, not a frizzy picture. It would also help to post links to the hardware items. There is a lot of stuff on the internet that will do what you want with out to much modification to the design.
