Arduino+Raspberry PI+PHP
Project: Php program that light on a led connected to the Arduino.
So I followed a few tutorials: php_serial.class.php+phpprogram.php+arduinoprogram.ino
I tried the same Arduino code with a python program and it works. Not fot PHP.
The Arduino reacts everytimes a execute the program , but the led doesn't light on.
For the php_serial.class.php, they only thing that needs to be changed is the serial port(I think):
	function deviceSet ($device)
		if ($this->_dState !== SERIAL_DEVICE_OPENED)
			if ($this->_os === "linux")
				if (preg_match("@^COM(\d+):?$@i", $device, $matches))
					$device = "/dev/ttyACM0" . ($matches[1] - 1);
				if ($this->_exec("stty -F " . $device) === 0)
					$this->_device = $device;
					$this->_dState = SERIAL_DEVICE_SET;
					return true;
As for the php program :
 <?php
include("php_serial.class.php");
$serial = new phpSerial();
$serial->deviceSet("/dev/ttyACM0");
$serial->confBaudRate(9600); //Baud rate: 9600
$serial->confParity("none"); //Parity (this is the "N" in "8-N-1")
$serial->confCharacterLength(8); //Character length (this is the "8" in "8-N-1")
$serial->confStopBits(1); //Stop bits (this is the "1" in "8-N-1")
$serial->confFlowControl("none"); //Device does not support flow control of any kind, so set it to none.
//Now we "open" the serial port so we can write to it
$serial->deviceOpen();
$serial->sendMessage("*1" ); //sleep(1); // echo "hi"; $serial->deviceClose();
Arduino code :
int OLight1 = 5 ;
void setup(){
  // Open serial connection.
  pinMode(OLight1, OUTPUT);
void loop(){
  if(Serial.available() > 0){      // if data present, blink
    digitalWrite(OLight1, HIGH);
    digitalWrite(OLight1, LOW);
Any idea ? Thank you
Opening the serial port resets the Arduino. Sending serial data before the Arduino is ready is a good way to ensure that the data is lost.
Once the data actually gets to the Arduino, don't you suppose that reading it would be a good idea?
It actually works by adding this : sleep(3);
Serial.available() > 0 is enought to initiate the blink. Once it receives data(whatever the size), it starts.
 <?php
sleep(3); ADDED CODE
$serial->sendMessage("*1" ); //sleep(10); // echo "hi"; $serial->deviceClose();
Sure, but if you actually read the serial data, you could see whether blinking should start or stop, or which pin should blink, or what the PWM value for a pin should be, or...
If your python program has no time.sleep() between open and write, u might use python php bridge to bridge python into php. I highly doubt is the case.
http://pecl.php.net/package/python
sleep(3) is not solution but Band-Aid.
