Arduino Raspberry PIR Optocoupler Switch
Hi guys Ive been playing with a project that has a pir sensor and originally had a relay control and i have swapped it out for optocoupler to trigger a momentary push button to shutdown the pi I can get it to shut down but nothing comes back up with the "button push" until i manually jump the pins I dont know if this is the right forum to post in but im just doing circles here is the code
#include <FastLED.h>
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 10;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 120000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 2;    //the digital pin connected to the PIR sensor's output
int relayPin = 4;
int buttonPin = 8;
#define MARQUEE_PIN     11
#define BACKLIGHT_PIN     12
#define COLOR_ORDER GRB
#define CHIPSET     WS2812B
#define NUM_LEDS    150
#define initBRIGHTNESS  40
#define BRIGHTNESS  100
#define FRAMES_PER_SECOND 500
int MARQcolor = CRGB::White;
int BACKcolor = CRGB::Blue;
int lightState = 0; //0 off, 1, fading up, 2 on, 3 fading down
int fadeStep = 0;
int fadeStepSize = 2;
bool isAnimating = 0;
CRGB MARQ_leds[NUM_LEDS];
CRGB BL_leds[NUM_LEDS];
//SETUP
void setup(){
  pinMode(buttonPin, INPUT);
  pinMode(pirPin, INPUT);
  pinMode(relayPin, OUTPUT);
  pinMode(MARQUEE_PIN, OUTPUT);
  pinMode(BACKLIGHT_PIN, OUTPUT);
  digitalWrite(pirPin, LOW);
  FastLED.addLeds<CHIPSET, BACKLIGHT_PIN, COLOR_ORDER>(BL_leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.addLeds<CHIPSET, MARQUEE_PIN, COLOR_ORDER>(MARQ_leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness( initBRIGHTNESS );
  if(digitalRead(buttonPin) == HIGH){
    digitalWrite(relayPin,LOW);
for( int j = 0; j < 20; j++) {
      MARQ_leds[j] = CRGB::Orange;
      BL_leds[j] = CRGB::Orange;
    setAllBrightNess(10);
    FastLED.show();
  //give the sensor some time to calibrate
  Serial.print("calibrating sensor ");
    for(int i = 0; i < calibrationTime; i++){
      Serial.print(".");
    Serial.println(" done");
    Serial.println("SENSOR ACTIVE");
    setAllBrightNess(0);
    delay(50);
     digitalWrite(relayPin,HIGH);
//LOOP
void loop(){
  // turn on sensors
     if(digitalRead(pirPin) == HIGH){
       if(lockLow){
         //makes sure we wait for a transition to LOW before any further output is made:
         lockLow = false;
         Serial.println("---");
         Serial.print("motion detected at ");
         Serial.print(millis()/1000);
         Serial.println(" sec");
         if(lightState  != 2){
          lightState = 1;
         delay(50);
         takeLowTime = true;
     if(digitalRead(pirPin) == LOW){
       if(takeLowTime){
        lowIn = millis();          //save the time of the transition from high to LOW
        takeLowTime = false;       //make sure this is only done at the start of a LOW phase
       //if the sensor is low for more than the given pause,
       //we assume that no more motion is going to happen
       if(!lockLow && millis() - lowIn > pause){
           //makes sure this block of code is only executed again after
           //a new motion sequence has been detected
           lockLow = true;
           Serial.print("motion ended at ");      //output
           Serial.print((millis() - pause)/1000);
           if(lightState != 0){
            lightState= 3;
           FastLED.show();
           delay(50);
    switch(lightState){
    case 0:
    //light is off
    case 1:
      //light is animating up
      lightIsAnimatingUp();
    case 2:
      //light is on
      lightIsOn();
    case 3:
      //light is animating down
      lightIsAnimatingDown();
  FastLED.show(); // display this frame
    //sensors are off.. just light up.
    for( int j = 0; j < NUM_LEDS; j++) {
      MARQ_leds[j] = MARQcolor;
      BL_leds[j] = BACKcolor;
    setAllBrightNess(BRIGHTNESS);
    FastLED.show();
void setColors(){
void lightIsOn()
  setColors();
  delay(100);
void lightIsAnimatingUp(){
    fadeStep+=fadeStepSize;
    setColors();
    setAllBrightNess(fadeStep);
    Serial.println(fadeStep);
    delay(50);
    if (fadeStep == BRIGHTNESS){
      isAnimating=0;
      lightState = 2;
void lightIsAnimatingDown(){
    fadeStep-=fadeStepSize;
    setColors();
    delay(50);
  if (fadeStep == 0){
      isAnimating=0;
      lightState = 0;
int setAllBrightNess(int val){
    FastLED.setBrightness( val );
I'm not sure what you code has to do with the scheme of things.
You talk about a PIR and a PI, you thread title mentions an Arduino, but its not even mentioned in you first post :o :o :o :o :o :o
PS Please read what you have written, then look at the thread subject you have given.
