Hi all I've been working on a wifi bot project interfaced with the serial port of a fonera and a python script that sends commands through an SSH session with the router. Im using a startbyte to read the values in the buffer then assign them to spaces in an array. A switch statement then sets the correct pin on or off.
Im getting stuck with the steering part. It uses a potentiometer to relay the position of the steering arm. In the ways I've attempted to write it it wont break out of the switch statement. So I'm looking for advice on a better way to write it
Here's a snippet of the code I'm using:
// the measured stop points using the values of analogRead are
// leftStop = 280;
// rightStop = 800;
switch (axis){
case 49: // 1 - forward
if (userInput[1] == 49) { digitalWrite(drive1[0], HIGH);}
else if (userInput[1] != 49) { digitalWrite(drive1[0], LOW);}
case 50: // 2 - reverse
if (userInput[1] == 49) { digitalWrite(drive2[0], HIGH);}
else if (userInput[1] != 49) { digitalWrite(drive2[0], LOW);}
case 51: // 3 - left
case 52: // 4 - right
case 121: // y turns off forward and reverse motors
case 120: // x centers steering
I think you need to post all the code rather than the snippet, as I can't see why that should go into the switch and not come out.
There is a } missing at the end but I assume it is just been missed out in the copy.
Things like this:-
should be simplified to:-
else { digitalWrite(drive1[0], LOW);}
you don't need the second IF because this condition is met if the first is not.
//Working Bot Control w/o steering w/ fonera and joystick
int driveArray[4] = {7, 6, 5, 4};
int userInput[2];
int startbyte;
int axis;
int action;
int drive1[2];
int drive2[2];
int drive3[2];
int drive4[2];
// Steering
int potPin = 0;
int val = 0;
int rightStop = 800;
int leftStop = 280;
int centerStop = (leftStop + rightStop)/ 2;
for (int i = 0; i < 4; ++i)
pinMode(driveArray[i], OUTPUT);
// map pins to drive direction
drive1[0] = driveArray[0]; // forward
drive2[0] = driveArray[1]; // reverse
drive3[0] = driveArray[2]; // left
drive4[0] = driveArray[3]; // right
//set all to off
digitalWrite( driveArray[i], LOW);
val = analogRead(potPin);
// Waits until theres 3 bytes in buffer
if (Serial.available() > 2)
// Read the first byte
startbyte = Serial.read();
if (startbyte == 122) {
for (int i = 0; i < 2; ++i)
userInput[i] = Serial.read();
Serial.println(startbyte);
// Which axis to move
axis = userInput[0];
action = userInput[1];
switch (axis){
Well, it's usually a good idea to have a trap "default" in a switch (helps debugging).
What makes you think you're not getting out of the switch?
Are you sending a continuous stream of triplets of characters (122, axis, action) on the serial line? If you're not, you'll stall after the first time through "loop"
You could simplify this somewhat - you've assigned "axis" and "action" but then reverted to "userInput[1]" instead of "action".
Not a big deal, but this sort of thing often comes back to bite you in the ass.
You could save time by: #define action userInput[1]
You're not using the value read from "potPin" - if you're debugging, and you don't need it, simply comment it out.
It sends triplets every time any time the joystick is pushed past a point a certain point on the given axis (255, axis, action) and also when it returns to the center positions on the x or y axis
For the steering parts I had something like the following before removing it and trying to start again. It is supposed to move in one direction until the pot value reaches a point then it'll break out of the while loop turn off that pin and break out of the switch
if (action == 49)
while (val > leftStop)
digitalWrite(drive3[0], HIGH);
digitalWrite(drive3[0], LOW);
if (action == 49)
while (val < rightStop)
digitalWrite(drive4[0], HIGH);
digitalWrite(drive4[0], LOW);
