Cannot get the results to show up in the serial monitor. Another person has had the same problem. Several answers to his problem but I think the best is this.
" rc switch library relies on transmitting device using a sc2262 or equivalent data encoding chip."
I am trying to decode a transmission from a remote control of a mains power switch. So I guess that I may need to take the transmitter apart to have a look.
I added another line to the code to print '5' but even that did not show up on the serial monitor. I am using com3 which works ok for all the arduino sketches I have created on the nano board. Could the example be using a different com port?
I am using the rxn3-b receiver module. It shows the numbers 434 and 315. I suppose this means for receiving transmissions of 434mhz and 315mhz. The transmitter is a 433mhz type.
Anybody know how to make this example work? Never had any problem with any of the other arduino examples. Anybody know of a gadget which displays remote control transmission codes? An oscilloscope I suppose. But what about something simpler?
