Arduino read AT Commands from Quectel M95 GSM Module
Objective: Submit AT Commands to the Quectel M95 (GSM2 Click http://www.mikroe.com/click/gsm2/) via SoftwareSerial/Arduino and parse responses; no Arduino GSM library.
Current condition: Able to fully communicate with the M95 via terminal at a variety of baud rates (9600 - 115200). AT Commands can be submitted and the desired result codes are present. I have tried with a different modem (DroneCell) with same results. All wiring has been checked 10 times and verified correct. If I submit AT commands via SoftwareSerial I know the modem is receiving the data as I can send an SMS, enact GPRS, etc; just can’t get valid responses.
Issue: Arduino is unable to read GSM Module responses using the below code. Result is garbled text/chars - variable and unpredictable. The expected response when submitting AT Command “AT” is “OK.”
#include <SoftwareSerial.h>
#define rxPin 10
#define txPin 11
SoftwareSerial mySerial(rxPin,txPin); // RX, TX
void setup(){
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  Serial.println("Arduino serial initialized!");
  delay(10);
  mySerial.begin(9600);
  Serial.println("Software serial initialized!");
  delay(10);
void loop(){
  issueCommand("AT");
  readSerial();
  while(true){
    readSerial();
void issueCommand(char* msg){
  mySerial.println(msg);
  Serial.print(msg);
  delay(10);
void readSerial(){
  while (mySerial.available()){
    Serial.write(mySerial.read());
    delay(10);
Needs explaining. How is the terminal application connected to the M95?
Terminal can communicate with the M95 via USB UART. Pins are VCC, GND, PWK (High), TX, and RX.
