this is my arduino code
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
#include "DHT.h"
#define DHTPIN 22
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "xxx.com"; // name address for Google (using DNS)
IPAddress ip(192,168,1,109);
int temp;
int moi;
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server,80)) {
Serial.println("connected");
// Make a HTTP request:
temp = dht.readTemperature();//dht11
moi = analogRead(15); //soil moisture
Serial.println(temp);
Serial.println(moi);
Serial.print("server name : ");
Serial.println(server);
client.print( "GET /add.php?"); // php??
client.print("temp1=");
//client.print(tempValue);
client.print(temp);
client.print("&&");
client.print("moi1=");
//client.print(levelValue);
client.print(moi);
client.println( " HTTP/1.1");
client.println( "Host: xxx.com" );//ur web server
client.println( "Content-Type: application/x-www-form-urlencoded" );
client.println( "Connection: close" );
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while(true);
add.php
<?php
include("conec.php");
$link=Conection();
$Sql="insert into tempmoi (temp1,moi1) values ('".$_GET["temp1"]."', '".$_GET["moi1"]."')";
mysql_query($Sql,$link);
header("Location: insertareg.php");
conec.php
<?php
function Conection(){
if (!($link=mysql_connect("localhost","user","pass"))) {
exit();
if (!mysql_select_db("table",$link)){
exit();
return $link;
insertareg.php
<html>
<head>
<title>Data of Sensor</title>
</head>
<body>
<h1>Data from the temperature and moisture sensors</h1>
<form action="add.php" method="get">
<TABLE>
<tr>
<td>Temperature 1</td>
<td><input type="text" name="temp1" size="20" maxlength="30"></td>
</tr>
<tr>
<td>Moisture 1</td>
<td><input type="text" name="moi1" size="20" maxlength="30"></td>
</tr>
</TABLE>
<input type="submit" name="accion" value="enter">
</FORM>
<hr>
<?php
$link=Conection();
$result=mysql_query("select * from tempmoi order by id desc",$link);
<table border="1" cellspacing="1" cellpadding="1">
<tr>
<td> Date and Time </td>
<td> Temperature 1 </td>
<td> Moisture 1 </td>
</tr>
<?php
while($row = mysql_fetch_array($result)) {
printf("<tr><td> %s </td><td> %s </td><td> %s </td></tr>", $row["dat"],$row["temp1"], $row["moi1"]);
mysql_free_result($result);
</table>
</body>
</html>
this is my reference http://www.instructables.com/id/Save-data-of-temperature-and-humidity-on-MySQL-wit/?ALLSTEPS
