Arduino reading garbage from SIM900
Hey Guys and Gals :grinning: ,
I wrote this sketch to send the command “AT” to the SIM900
So things I would like to eliminate:
1.The RX and TX pins are in the right place.
2.The Sim 900 Board works, I have tested it with other sketches.
3.I have tried other commands like AT+CSQ.
See below my sketch:
#include <SoftwareSerial.h>
SoftwareSerial SIM900(2, 3);
  SIM900.begin(19200);
  Serial.println("Comm's initiated");
  SIM900power();
  Serial.println("SIM 900 Power Cycle Completed");
  SIM900.write("AT");
  Serial.println("Sent AT Command");
  while (SIM900.available() > 0)  {
    char ch = SIM900.read();
    Serial.println(ch);
void SIM900power()  {
  digitalWrite(8, HIGH);
  delay(5000);
  digitalWrite(8, LOW);
  delay(10000);
So when I upload the sketch and open the serial monitor I should see this(or atleast this is what I think I should be seeing :wink: ):
Comm’s initiated
Sent AT Command
OK <<< THIS BEING THE SIM900 AFTER EXECUTING THE AT COMMAND
But this is what I am seeing
SEE ATTACHED IMAGE OF SERIAL MONITOR
So I’m note sure if I’ve left something out of if I’ve done something wrong. Does anyone out there know why I’m receiving this?
Thanks Cal
Are ypu sure the baud is 19200 bps?
I think the default baud for SIM900 is 115200 bps
Give it a try
  SIM900.write("AT");
I think you should move this while to your loop function since serial comunication are slow and you could hit that while more fast than the incoming bytes are arriving to serial buffer
Thanks for the replay... you know what the problem was... drum roll... the baud rate was supposed to be 4600 so you wernt of on the problem :wink:
My new issue is to take the data from the SIM 900 and try and manipulate it lol
Thank you again! :grinning: :grinning: :grinning:
The SIM900? Which board are you using?
Its a board I made myself,
Well done.Your board makes me remember old days when I also make boards by hand.
Good job :slight_smile:
