Arduino & RealBasic under WinXP
I tried the run this in Realbasic(2007r5) under WinXP
  Serial1.SerialPort=System.SerialPort("/COM6")
  If Serial1.Open then
    Serial1.Write("H")
  Else
    MsgBox "The serial port could not be opened."
  End if
and this on the arduino (NG)
int ledPin = 13;
int val = -1;
  pinMode(ledPin,OUTPUT);
void loop () {
  val = Serial.read();
  if (val !=-1){
    if (val == 'H'){
      digitalWrite(ledPin,HIGH);
      delay(200);
      digitalWrite(ledPin,LOW);
It works from the serial monitor in arduino but not Realbasic any idea anybody?
I don't know realBasic, but it looks like you are just opening the port i RealBasic without specifying any paramaters for baud rate, parity etc.
What are the default values ? You should probably make sure the values match those on the Arduino board.
The baud rate is specified in the parameters for the object serial1, "serial1" is a serial object that you drop into window1.
The example your using was coded for a mac, so try
Serial1.SerialPort=System.SerialPort("\.\COM6")
If that fails, drop a list box into window1, then in the Open event handlers, add this
dim i as Integer
for i = 0 to System.SerialPortCount - 1
ListBox1.AddRow( System.SerialPort(i).Name)
next
Run the program and see which COM ports are visible in the listbox
