arduino reboots upon calling wire.RequestFrom
Hey fellows,
i think the title says it all, I'm trying to read from a sensor connected through i2c but as soon as wire.requestFrom() is called, my arduino mega 2560 reboots. Here's the code, if anybody sees something dubious, please tell me.
  #include <LiquidCrystal.h>
  #include <Wire.h>
  #define ADRESSE_SUIVEUR 0x28
  const int PIN_OUT = 43;
  const int C1 = 31;
  const int C2 = 33;
  const int C3 = 35;
  const int C4 = 37;
  const int C5 = 39;
  const int power = 40;
  const int ground = 50;
  byte donnees = B00000000;
  LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
  void setup(){
    Wire.begin();
    pinMode(C1,OUTPUT);
    pinMode(C2,OUTPUT);
    pinMode(C3,OUTPUT);
    pinMode(C4,OUTPUT);
    pinMode(C5,OUTPUT);
    pinMode(power, OUTPUT);
    digitalWrite(power,HIGH);
    pinMode(ground, OUTPUT);
    digitalWrite(ground, LOW);
    lcd.print("INIT SUIVEUR");
    delay(2000);
    lcd.clear();
  void loop(){
    traitementSuiveur(updateSuiveur());
    delay(250);
  byte updateSuiveur(){
    lcd.print(" update");
        byte byteSuiveur = B00000000; //byte storing sensor state
        lcd.print(" byte request");
        Wire.requestFrom(ADRESSE_SUIVEUR,1);
        lcd.clear();
        lcd.print(" req sent");
        if (Wire.available()){
          lcd.print("wire connected");
          byteSuiveur = Wire.read();
        else{
          lcd.print("wire not connected");
        return  byteSuiveur = byteSuiveur & 0x1f; // set first 3 bits at 000
  void traitementSuiveur(byte byteSuiveur){
    int signalOut = 0;
        switch(byteSuiveur){
               case B00000110:
                signalOut = 132; //2.5V
                lcd.clear();
                lcd.print("--x--");
                analogWrite(PIN_OUT, signalOut);
              case B00000010:
                signalOut = 110; //2V
                lcd.clear();
                lcd.print("---x-");
              case B00001010:
                signalOut = 155; //3V
                lcd.clear();
                lcd.print("-x---");
             case B00010010:
                signalOut = 205; //4V
                lcd.clear();
                lcd.print("x----");
              case B00000011:
                signalOut = 51; //1V
                lcd.clear();
                lcd.print("----x");
              case B00011111:
                signalOut = 0;
                lcd.clear();
                lcd.print("all black");
               case B00000000:
                signalOut = 0;
                lcd.clear();
                lcd.print("all white");
Does it reboot if you have nothing connected to the I2C bus?
Does it reboot if nothing is connected to it, other than the sensor?
If nothing is connected to the I2C bus, it does not reboot.
and there is only that very sensor connected.
So, nothing connected to these pins?
const int C1 = 31;
const int C2 = 33;
const int C3 = 35;
const int C4 = 37;
const int C5 = 39;
What sensor is it? Link to the datasheet please.
