Hello,
I have a HC-05 connected to an Arduino-nano via software serial. I’m using the HC-05 to receive input from a bluetooth gamepad. The gamepad sends its input as a single byte, which the HC-05 transmits to the Arduino.
Problem is, the Arduino is not receiving the correct data from the HC-05. If the controller is transmitting “0” the Arduino receives a random mix of “10”, “13”, and “48” (but never 0).
I’ve connected the HC-05 directly to my PC using my USB to Serial and have verified that the HC-05 is receiving and transmiting the correct data from the controller. So the problem is somewhere in the connection between the HC-05 and the arduino.
I’ve tried both software and hardware serial, and both have the same behavior.
Here is my code:
#include <SoftwareSerial.h>
// Setup software serial for Bluetooh. RX = 10, TX = 11
SoftwareSerial bSerial (10, 11);
int controllerPins[] = {2, 3, 4, 5, 6, 7, 8, 9};
bSerial.begin(9600);
for(int i = 0; i < 8; i++) {
pinMode(controllerPins[i], OUTPUT);
void ProcessInput(byte input) {
digitalWrite(controllerPins[i], !(input >> i & 1));
if(bSerial.available()) {
int data = bSerial.read();
Serial.println((byte) data);
ProcessInput((byte) data);
I’ve tried this without the cast to byte and with Serial.readBytes() with no luck.
The connections are as follows:
HC-05 ----- Arduino
GND → GND
VCC → VCC (3.3v)
TX → pin 10 (software serial RX)
RX → pin 11 (software serial TX)
Any thoughts would be greatly appreciated!
