I write a lot of code.
I am using Arduino latest version.
I use AT-T to reformat code a lot. If there is a code error (wrong syntax) then AT-T often inserts spaces into strings and rearranges code following the statement [not before the statement].
This is really annoying.
Especially strings like "/anything.json" will be reformatted as " / anything.json"
To observe this behaviour the following code...
// this shows arduino reformatting error
#include <Arduino.h>
// the following code is an error
// when you press ALT-T to reformat code without fixing error, note statement actually changes
if ( mySetupData<-get_answer() == false ))
// Note string below also get changed !!!!!!!!!!!!!!!!!! [ insertion of spaces in strings ]
Serial.print("Debug output is );
// const String filename = "/wificonfig.json";
arduinoformaterror.ino (564 Bytes)
