Arduino relay boards
Hi, I am completely and utterly new to Arduino... My wife wanted me to make some controlled christmas lights for the next holiday and I started research, found the Arduino, ordered one and it arrived yesterday. My plan is to couple the Arduino with a 8 channel 5v relay module.. I have also seen 2,4 and 16 channel relay boards for the arduino.... Is there a limitation that the Arduino Uno can support natively, otherwise I might as well get a 16 channel...
Hi guys, I am new to Arduino, my wife wanted me to make controlled christmas lights so here I am.
My plan is to couple an Arduino Uno (which arrived yesterday) with a relay module (like this one http://dx.com/p/8-channel-5v-relay-module-w-optocoupler-for-arduino-red-blue-223585?tc=AUD&gclid=CLrYndie8rsCFQYepAodJUwA8Q ) .
Since I cannot test programming a relay I dont have, I was wondering if there are limitations to the amount of relays I can control with an Uno... Because If I can control more I might as well go for a 16 Channel.
Any tips, suggestions would be greatly apreciated.
with various other devices, you could control millions of relays.
A 7hc595 shift register will control 8 relays, 2 of them chained together will give 16 outputs (or higher still with 3 or more)
Easy (3 pins to control hundreds of relays)
Please do not cross-post. Topics merged.
Thank Coding Badly, wont happen again.
cjdelphi:
Forgive my ignorance.... but is the 7hc595 shift register already on the arduino board?
Eelko:
cjdelphi:
Uh, no.
If you wish to use just an Arduino, you'd have to turn ALL the pins into digital outputs including the analog ports, A0,A1.... etc which might supply enough pin outs.
http://www.ebay.com.au/itm/5-PCS-74HC595N-74HC-595N-595-8-bit-Shift-Register-IC-DIP-16-PIN-TEXAS-New-ICs-/270916565844?pt=AU_B_I_Electrical_Test_Equipment&hash=item3f13e2bb54
cjdelphi:
Uh, no.
Ah, ok, that makes sense...
Since the Uno has fourteen digital pins and another six that can be used for either analog or digital purposes, you'll be fine with a sixteen relay board. Digital pins 0 and 1 are used for the serial port - uploading your code and debugging your application so best not to use them, but even reserving them, you can control sixteen channels with a couple of pins left over.
Thanks Wildbill :slight_smile:
I had a think about it overnight, Ill get an 8 first and then if all goes well buy a 16.... it's not like they cost a fortune...
Sounds like you figured out how the game works :wink: Took me 30 years!
A four page tutorial for making a parallel port Christmas light controller, which you could duplicate with an arduino.
http://computerchristmas.com/christmas/link-how_to/HowToId-4/How_To_Build_A_Parallel_Port_Controller_Box
