Arduino Relay Timer Scale up issue
I have code that i built initially for my Arduino Uno to control 8 outlets through an Elegoo 8 Channel DC 5V Relay Module. The timer schedule worked fine for these 8 relays, however when i scaled up to 16 relays, adding a second module to the arduino I started having issues with the schedule. The outlets would remain active when they should be disabled, and other similar issues indicating that is a bug in time tracking. This was confusing to me since the same code handled the 8 relays without issue. I have dedicated power to the arduino and the relay. Also when i test the function of each relay (controlled by arduino) individually all get energized and disabled as intended.
I have posed the code below and I would appreciate any feedback.
Thank you
This sketch turns each of the 16 relays on and then off, based on a daily 'on' time, a duration and cycle. Once the cycle time completes the sequence repeats
Uses arrays and for statements
HIGH TURNS RELAY OFF
long Out1 = 6;
long Out2 = 8;
long Out3 = A4;
long Out4 = 7;
long Out5 = 9;
long Out6 = A3;
long Out7 = A0;
long Out8 = 4;
long Out9 = 2;
long Out10 = A1;
long Out11 = 5;
long Out12 = 3;
long Out13 = A2;
long Out14 = 10;
long Out15 = A5;
long Out16 = 11;
long pinArray[] = {Out1, Out2, Out3, Out4, Out5, Out6, Out7, Out8, Out9, Out10, Out11, Out12, Out13, Out14, Out15, Out16}; // define the pins that will connect to the relays
long relayStateArray[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; // track the state of a relay (on or off). Start with the first one on.
//IintTimeMat{} = {Hr,mm,ss}
long InitTimeMat[] = {7,57,00};
long InitTime = InitTimeMat[0]*3600+InitTimeMat[1]*60+InitTimeMat[2]; //time of date when arduino is reset
//long InitTime = 0; //time of date when arduino is reset
long Cycles = 0; //number of cycles passed since arduino reset
//long CycleLen = 60; // length of a 'day' in seconds
long CycleLen = 86400; // length of a 'day' in seconds
float CurrentSecCalc = 0; // variable to track the current "time" -- milliseconds since last time the Arduino was reset
float CurrentSec = 0; // variable to track the current "time" -- milliseconds since last time the Arduino was reset
long previousMillis[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; // variable to track the last time a relay state was changed
//StartTime#[] = {Hr,mm,ss}
long StartTime1[] = {5,0,5};
long STS1 = StartTime1[0]*3600+StartTime1[1]*60+StartTime1[2];
long StartTime2[] = {5,0,10};
long STS2 = StartTime2[0]*3600+StartTime2[1]*60+StartTime2[2];
long StartTime3[] = {5,0,15};
long STS3 = StartTime3[0]*3600+StartTime3[1]*60+StartTime3[2];
long StartTime4[] = {0,0,0};
long STS4 = StartTime4[0]*3600+StartTime4[1]*60+StartTime4[2];
long StartTime5[] = {0,0,0};
long STS5 = StartTime5[0]*3600+StartTime5[1]*60+StartTime5[2];
long StartTime6[] = {0,0,0};
long STS6 = StartTime6[0]*3600+StartTime6[1]*60+StartTime6[2];
long StartTime7[] = {0,0,0};
long STS7 = StartTime7[0]*3600+StartTime7[1]*60+StartTime7[2];
long StartTime8[] = {5,0,20};
long STS8 = StartTime8[0]*3600+StartTime8[1]*60+StartTime8[2];
long StartTime9[] = {5,0,5};
long STS9 = StartTime9[0]*3600+StartTime9[1]*60+StartTime9[2];
long StartTime10[] = {0,0,0};
long STS10 = StartTime10[0]*3600+StartTime10[1]*60+StartTime10[2];
long StartTime11[] = {0,0,0};
long STS11 = StartTime11[0]*3600+StartTime11[1]*60+StartTime11[2];
long StartTime12[] = {5,0,10};
long STS12 = StartTime12[0]*3600+StartTime12[1]*60+StartTime12[2];
long StartTime13[] = {5,0,15};
long STS13 = StartTime13[0]*3600+StartTime13[1]*60+StartTime13[2];
long StartTime14[] = {0,0,0};
long STS14 = StartTime14[0]*3600+StartTime14[1]*60+StartTime14[2];
long StartTime15[] = {0,0,0};
long STS15 = StartTime15[0]*3600+StartTime15[1]*60+StartTime15[2];
long StartTime16[] = {0,0,0};
long STS16 = StartTime16[0]*3600+StartTime16[1]*60+StartTime16[2];
//long StartTime[] = {5,20,00,0,0,0,0,0}; // array for Start time for each outlet in seconds
long StartTime[] = {STS1, STS2, STS3, STS4, STS5, STS6, STS7, STS8, STS9, STS10, STS11, STS12, STS13, STS14, STS15, STS16}; // array for Start time for each outlet in seconds
//OnTime#[] = {Hr,mm,ss}
long OnTime1[] = {18,0,0};
long OTS1 = OnTime1[0]*3600+OnTime1[1]*60+OnTime1[2];
long OnTime2[] = {18,0,10};
long OTS2 = OnTime2[0]*3600+OnTime2[1]*60+OnTime2[2];
long OnTime3[] = {18,0,20};
long OTS3 = OnTime3[0]*3600+OnTime3[1]*60+OnTime3[2];
long OnTime4[] = {0,0,0};
long OTS4 = OnTime4[0]*3600+OnTime4[1]*60+OnTime4[2];
long OnTime5[] = {0,0,0};
long OTS5 = OnTime5[0]*3600+OnTime5[1]*60+OnTime5[2];
long OnTime6[] = {0,0,0};
long OTS6 = OnTime6[0]*3600+OnTime6[1]*60+OnTime6[2];
long OnTime7[] = {0,0,0};
long OTS7 = OnTime7[0]*3600+OnTime7[1]*60+OnTime7[2];
long OnTime8[] = {18,0,30};
long OTS8 = OnTime8[0]*3600+OnTime8[1]*60+OnTime8[2];
long OnTime9[] = {18,0,0};
long OTS9 = OnTime9[0]*3600+OnTime9[1]*60+OnTime9[2];
long OnTime10[] = {0,0,0};
long OTS10 = OnTime10[0]*3600+OnTime10[1]*60+OnTime10[2];
long OnTime11[] = {0,0,0};
long OTS11 = OnTime11[0]*3600+OnTime11[1]*60+OnTime11[2];
long OnTime12[] = {18,0,10};
long OTS12 = OnTime12[0]*3600+OnTime12[1]*60+OnTime12[2];
long OnTime13[] = {18,0,20};
long OTS13 = OnTime13[0]*3600+OnTime13[1]*60+OnTime13[2];
long OnTime14[] = {0,0,0};
long OTS14 = OnTime14[0]*3600+OnTime14[1]*60+OnTime14[2];
long OnTime15[] = {0,0,0};
long OTS15 = OnTime15[0]*3600+OnTime15[1]*60+OnTime15[2];
long OnTime16[] = {0,0,0};
long OTS16 = OnTime16[0]*3600+OnTime16[1]*60+OnTime16[2];
//long OnTime[] = {30,35,00,0,0,0,0,0}; // array for duration each outlet will remain on in seconds
long OnTime[] = {OTS1, OTS2, OTS3, OTS4, OTS5, OTS6, OTS7, OTS8, OTS9, OTS10, OTS11, OTS12, OTS13, OTS14, OTS15, OTS16}; // array for duration each outlet will remain on in seconds
long i = 0; // used for the "for" statements (loops that cycle through all 8 relays).
for (i = 0; i < 16; i++) { // set the pinMode to OUTPUT for the 8 pins that connect to the relays
  pinMode(pinArray[i], OUTPUT);
CurrentSec =  millis() / 1000;
if ((InitTime + CurrentSec) / CycleLen - Cycles >= 1)
  ++Cycles;
CurrentSecCalc = CurrentSec - Cycles * CycleLen + InitTime; // set this variable to the current Arduino time
  if ((relayStateArray[i] == LOW) && ((CurrentSecCalc >= StartTime[i] + OnTime[i]) or (CurrentSecCalc < StartTime[i]))) //if a rmax relay is on and reached the end of schedule
  { relayStateArray[i] = HIGH; // turn it off...
    previousMillis[i] = CurrentSecCalc; // record the time of this change in state to the relay...
  //when the first statement fials the relay either is still scheduled to stay on or is currently off
  else  if ((relayStateArray[i] == HIGH) && (CurrentSecCalc >= StartTime[i]) && (CurrentSecCalc <= + OnTime[i] + StartTime[i])) //If a relay is off and it is time to turn on...
  { relayStateArray[i] = LOW; // turn it on...
  }//if conditions fail both statements the relay is off as scheduled
  digitalWrite(pinArray[i], relayStateArray[i]); // the above just changes the value in the state array. This turns the relay on or off based on that value.
Serial.print(CurrentSecCalc/60);
Serial.print('\n');
/*Serial.print(Cycles);
  Serial.print('\n');*/
First mistake
    pinMode(pinArray, OUTPUT);
You need to index pinArray this way
Same problem with relayStateArray, use relayStateArray
All arrays are without indexing.
OnTime, StartTime, CurrentSecCalc, relayStateArray.
See what happened there? Your array indexers have all disappeared because you did not post your code in code tags. How to use the forum. See #7. The missing indexers make it more difficult to see what the code is doing. Your code would be easier to read if you use the auto format tool (ctrl-t or Tools, Auto Format) to indent the code. Consistent placement of brackets would help readability, too.
[i] is the forum software tag for italics.  So it put the rest of the code in italics and removed the tags
Sorry, i have fixed the code formatting issue in the post. Thanks
