I'm trying to use this example from arduino to get weather from api, but it resets. I'm using Arduino Uno and a WiFi Shield. What can the problem be?
#include <SPI.h>
#include <ArduinoJson.h>
#include<WiFi.h>
#define JSON_BUFF_DIMENSION 2500
char ssid[] = "Ornelas'"; // your network SSID (name)
char pass[] = "LucasOrnelas"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
String nameOfCity = "Turin,IT"; // your city of interest here in format "city,countrycode"
String text;
int endResponse = 0;
boolean startJson = false;
int status = WL_IDLE_STATUS;
const char server[] = "api.openweathermap.org"; // name address for openweathermap (using DNS)
WiFiClient client;
unsigned long lastConnectionTime = 10 * 60 * 1000; // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 10 * 60 * 1000; // posting interval of 10 minutes (10L * 1000L; 10 seconds delay for testing)
//Initialize serial and wait for port to open:
text.reserve(JSON_BUFF_DIMENSION);
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the status:
printWifiStatus();
// if ten minutes have passed since your last connection,
// then connect again and send data:
if (millis() - lastConnectionTime > postingInterval) {
// note the time that the connection was made:
lastConnectionTime = millis();
httpRequest();
char c = 0;
if (client.available()) {
c = client.read();
// json contains equal number of open and close curly brackets, therefore by counting
// the open and close occurences, we can determine when a json is completely received
// endResponse == 0 means equal number of open and close curly brackets reached
if (endResponse == 0 && startJson == true) {
parseJson(text.c_str()); // parse c string text in parseJson function
text = ""; // clear text string for the next time
startJson = false; // set startJson to false to indicate that a new message has not yet started
if (c == '{') {
startJson = true; // set startJson true to indicate json message has started
endResponse++;
if (c == '}') {
endResponse--;
if (startJson == true) {
text += c;
void parseJson(const char * jsonString) {
StaticJsonBuffer<4000> jsonBuffer;
// FIND FIELDS IN JSON TREE
JsonObject& root = jsonBuffer.parseObject(jsonString);
if (!root.success()) {
Serial.println("parseObject() failed");
return;
JsonArray& list = root["list"];
JsonObject& now = list[0];
JsonObject& later = list[1];
String city = root["city"]["name"];
float tempNow = now["main"]["temp"];
float humidityNow = now["main"]["humidity"];
String weatherNow = now["weather"][0]["description"];
float tempLater = later["main"]["temp"];
float humidityLater = later["main"]["humidity"];
String weatherLater = later["weather"][0]["description"];
printDiffFloat(tempNow, tempLater, "temperature", "*C");
printDiffString(weatherNow, weatherLater, "rain");
printDiffString(weatherNow, weatherLater, "snow");
printDiffString(weatherNow, weatherLater, "hail");
printDiffString(weatherNow, weatherLater, "clear");
printDiffFloat(humidityNow, humidityLater, "humidity", "%");
// this method makes a HTTP connection to the server:
void httpRequest() {
// close any connection before send a new request.
// This will free the socket on the WiFi shield
client.stop();
// if there's a successful connection:
if (client.connect(server, 80)) {
// Serial.println("connecting...");
// send the HTTP PUT request:
Serial.print("OK");
client.println("GET /data/2.5/forecast?q=" + nameOfCity + "&mode=json&units=metric&cnt=2 HTTP/1.1");
client.println("Host: api.openweathermap.org");
client.println("User-Agent: ArduinoWiFi/1.1");
client.println("Connection: close");
client.println();
else {
// if you couldn't make a connection:
Serial.println("connection failed");
void printDiffString(String now, String later, String weatherType) {
int indexNow = now.indexOf(weatherType);
int indexLater = later.indexOf(weatherType);
// for all types of weather except for clear skies, if the current weather does not contain the weather type and the later message does, send notification
if (weatherType != "clear") {
if (indexNow == -1 && indexLater != -1) {
Serial.println("Oh no! It is going to " + weatherType + " later! Predicted " + later);
// for clear skies, if the current weather does not contain the word clear and the later message does, send notification that it will be sunny later
else {
Serial.println("It is going to be sunny later! Predicted " + later);
void printDiffFloat(float now, float later, String parameter, String unit) {
String change;
if (now > later) {
change = "drop from ";
else if (now < later) {
change = "rise from ";
else {
return;
Serial.print("UPDATE: The " + parameter + " will " + change);
Serial.print(now);
Serial.print(unit + " to ");
Serial.print(later);
Serial.println(unit + "!");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
