Arduino reset with usb / serial converter
good personal afternoon, I rode in a breadboard arduino one to test, in line with the USB serial converter dtr has a 100nf capacitor connected in series and in parallel with a resistor 5v.
When you turn the board the program works perfectly, quano opens the ide Arduino board is resetting (close the program back to work perfectly). When a new program is downloaded it for reset and back to work.
It disconnects the USB and reconnects back to get resetanto (until a new program is descaregado or close the arduino ide)
When she is resetting I take the wire connected to the dtr it works perfectly.
The impression it gives is that when you connect to the Arduino IDE to the dtr can not work with a pulse so that the system can run (only works after recording a program)
Has anyone ever experienced this
Thank you very much
Yes some beginners report this and in all cases it has been found that they are making some mistake or misunderstanding.
This is not the way an Arduino behaves.
