Arduino Resetting continuosly when it reads data from SoftwareSerial....
I have hardware which specification is
Protocol:- Asynchronous serial interface
Baud Rate:-9600 baud
#Start bits:-1
#Data bits:-8
#Stop bits: -1
Parity:-None
when I am communicating with this hardware with my Arduino Nano 's Software serial my Arduino resetting after every loop executes.
Here is my code...
#include<SoftwareSerial.h>
#define SoftSerialRx_pin 6
#define SoftSerialTx_pin 5
SoftwareSerial mySerial(SoftSerialRx_pin,SoftSerialTx_pin);
int c,i=0,d[50];
float voltage,current;
bool flg = 0;
  mySerial.begin(9600);
  Serial.println("Setup call#################################################################################################");
  Serial.println("Loop call____________________________@@@@@@@@@@@@@@@@");
  DataTest();
void DataTest()
  c =0;
  mySerial.write(0xDD); mySerial.write(0xA5); mySerial.write(0x03); mySerial.write((byte)0x00); mySerial.write(0xFF); mySerial.write(0xFD); mySerial.write(0x77);
  while(c != 0x77)
  { if(mySerial.available())    {
          if((c = mySerial.read()) != -1)      {
             d[i] = c;           i++;
  Serial.print(" data : - ");
  for(int j =0 ; j< i ; j++)
    Serial.print(d[j], HEX);
    Serial.print("\t");
and output is
14:03:28.513 -> Loop call____________________________@@@@@@@@@@@@@@@@
14:03:28.595 ->  data : - DD	3	0	1B	4	AB	0	0	5	3F	5	DC	0	9	26	81	0	0	0	0	0	0	17	5A	3	3	1	B	90	0	0	FC	4E	77
14:03:28.695 -> Loop call_______________________
14:03:30.106 -> Setup call#################################################################################################
14:03:30.189 -> Loop call____________________________@@@@@@@@@@@@@@@@
14:03:30.282 ->  data : - DD	3	0	1B	4	AB	0	0	5	3F	5	DC	0	9	26	81	0	0	0	0	0	0	17	5A	3	3	1	B	90	0	0	FC	4E	77
14:03:30.369 -> Loop call_______________________⸮
14:03:31.808 -> Setup call#################################################################################################
14:03:31.910 -> Loop call____________________________@@@@@@@@@@@@@@@@
14:03:31.977 ->  data : - DD	3	0	1B	4	AB	0	0	5	3F	5	DC	0	9	26	81	0	0	0	0	0	0	17	5A	3	3	1	B	90	0	0	FC	4E	77
14:03:32.044 -> Loop call_______________________⸮
14:03:33.492 -> Setup call#################################################################################################
14:03:33.607 -> Loop call____________________________@@@@@@@@@@@@@@@@
14:03:33.643 ->  data : - DD	3	0	1B	4	AB	0	0	5	3F	5	DC	0	9	26	81	0	0	0	0	0	0	17	5A	3	3	1	B	90	0	0	FC	4E	77
14:03:33.781 -> Loop call_______________________⸮
so anyone has an idea, why is my Arduino resetting?
First a comment, NOTHING follows a ;. New command = new line!
And short variable names might sound like a time-saver but really, the compiler gives 0 F*. They are an aid for you, pick names that make sense.
Next, are you sure you receive <50 bytes? For the fun of it, print what you read an the value of i every time you do a read.
Ahh, while editing your code to be more sensible, you never reset 'i' :wink: Aka, you WILL overflow your array.
const byte SoftSerialRxPin = 6;
const byte SoftSerialTxPin = 5;
SoftwareSerial mySerial(SoftSerialRxPin,SoftSerialTxPin);
char dataArray[50];
const byte DataArrayLength = sizeof(dataArray);
  Serial.println(F("Setup call#################################################################################################"));
  Serial.println(F("Loop call____________________________@@@@@@@@@@@@@@@@"));
  dataTest();
void dataTest() {
  byte bytesReceived = 0
  for(char c = 0; (c != 0x77) && (bytesReceived < DataArrayLength); ) {
      c = mySerial.read();
      if(c != -1) {
        dataArray[bytesReceived++] = c;
  Serial.print(F(" data : - "));
  for(byte i = 0 ; i < bytesReceived; i++) {
    Serial.print(dataArray[i], HEX);
    Serial.print("\t");
