Hey, I am doing a school project and my most recent version of code seems to be causing my Arduino Uno to reset every time it gets to the loop. It can only run through the setup, from what I have read this may be a memory issue but I am not too sure about it. I would love some help.
The purpose of the code is a model carpark security system, it uses LDRs to read the position of the car and an H bridge to control DC motors for the barrier arms. I have also included a 16x2 LCD display.
I apologize if my code is sloppy, I have tried my best to clean it up but I am insanely busy with school work
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f,20,4); // set the LCD I2C address to 0x3f
//Setting the pins
const int LDR[] = {A0, A3, A1, A2}; //LDR pins
const int h[] = {9, 8, 7, 6};
const int buzzer = 13;
const int button[] = {2, 3, 4, 5, 10};
int val[] = {};
int but[] = {};
int ArmUp[] = {0, 0}; //Arm position
int roomValA, roomValB; //Room light values
int ticket;
int cars, carsIn, emptySpaces; //Value for tracking cars and spaces
int spaces = 10; //Number of total spaces
void setup() { //This code runs once when at the beginning of the code
//Begining the serial monitor at 9600 baud
Serial.println("Start");
for(int n = 0; n <= 4; n++){
pinMode(LDR[n], INPUT);
pinMode(button[n], INPUT_PULLUP);
pinMode(h[n], OUTPUT);
pinMode(buzzer, OUTPUT);//Declaring the buzzer as an output
pinMode(button[4], INPUT_PULLUP);//Decalring the button as an input
roomValA = ((analogRead(LDR[0])+ analogRead(LDR[1]))/200) - 1;
roomValB = ((analogRead(LDR[2]) + analogRead(LDR[3]))/200) - 1; //Averaging all the LDRs to get the room value then prints the value
sprintf("Room vals: %d /t %d", roomValA, roomValB);
lcd.init();// initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(1,0);
lcd.print("Car park system V4");
lcd.setCursor(1,1);
lcd.print("Made by Robin Nowlan");
lcd.clear(); //Sets up the LCD
void loop() { //Loops forever
//CODE RESETS AT THIS POINT
//Reading all the inputs
for(int i = 0; i <= 4; i++){
Serial.println("read");
val[i] = analogRead(LDR[i])/100;
Serial.println(val[i]);
but[i] = digitalRead(button[i]);
ticket = digitalRead(button[4]);
if(but[0] == 0){
LCDdisplay("Total cars:", cars);
if(but[1] == 0){
LCDdisplay("Cars in:", carsIn);
if(but[2] == 0){
LCDdisplay("Cars out:", cars - carsIn);
if(but[3] == 0){
LCDdisplay("Time up:", millis()/1000);
emptySpaces = spaces - carsIn;
Serial.print("Loop begin");
//Main control loop
if(val[0] < roomValA && ticket == LOW){
if(ArmUp[0] == 0){
for(int i = 0; i < 3; i++){
digitalWrite(buzzer, HIGH);
digitalWrite(buzzer,LOW);
delay(100);
digitalWrite(h[0], LOW);
digitalWrite(h[1], HIGH);
Serial.println("Entrance Arm Up");
cars ++;
carsIn ++;
for(int z; z <= 5000; z++){
LCDdisplay("Time to go",z/1000);
delay(1);
//delay(5000);
digitalWrite(h[1], LOW);
Serial.println("Entrance Arm Stop");
lcd.clear();
lcd.setCursor((16/2)-2, 0);
lcd.print("Go");
lcd.setCursor((16/4)+(16/2), 0);
lcd.print("|");
lcd.setCursor((16/4)+(16/2), 1);
lcd.print("V");
lcd.setCursor((16/4), 1);
lcd.print("X");
lcd.clear();
ArmUp[0] = 1;
else if(val[0] >= roomValA && val[1] < roomValA){
if(ArmUp[0] == 1){
delay(100);
digitalWrite(h[0], HIGH);
Serial.println("Entrance Arm Down");
delay(5000);
ArmUp[0] = 0;
//Second arm
if(val[3] < roomValB){
if(ArmUp[1] == 0){
delay(100);
digitalWrite(h[2], LOW);
digitalWrite(h[3], HIGH);
Serial.println("exit Arm up");
carsIn --;
delay(1);
//delay(4000);
digitalWrite(h[3], LOW);
Serial.println("Exit Arm stop");
ArmUp[1] = 1;
else if(val[3] >= roomValB && val[2] <= roomValB){
if(ArmUp[1] == 1){
delay(100);
digitalWrite(h[2], HIGH);
Serial.println("Exit Arm Down");
delay(4000);
Serial.println("Exit Arm stop"); ;
ArmUp[1] = 0;
void LCDdisplay(String x, int y){
lcd.clear();
lcd.print(x);
lcd.setCursor(1,1);
lcd.print(y);
The code compiles and uploads correctly but does not run, as well as this the serial monitor sometimes outputs gibberish rather than the expected outcome.
