Do you have a simple uno R3 to try the code on, just to rule out any issue with the wifi piece?
That will help you dig in the right place
Yes I have an Arduino UNO, I will test on this but it seems like the issue is with the USB library
[EDIT:] I have tested and the behavior persists with the Arduino UNO
Ok - then indeed need to dig into the USB behavior
Have you tried an active wait with a while loop + millis and calling Usb.Task() within the while to see if indeed that needs to be called "often enough"
For example calling this function instead of delay()
void hackedDelay(unsigned long duration)
unsigned long t0 = millis();
while (millis() - t0 < duration) {
Usb.Task();
