hi! im doing an LED Matrix Email Notifier which involves using python script.
the python script fetches the number of unread emails from my Gmail account every few minutes, and then sends it to my arduino (through pySerial extension). The arduino identifies the data, converts it into displays.
the problem is:
whenever python sends serial data ,my Arduino freezes up and restarts itself, it didn’t receive any data at all.
but it got the data fine when i tried sending some random values through the serial monitor.
help!any idea why this happened?
python script taken from: KodeClutz: GMail Notifier on an Arduino
import httplib
import getpass
import base64
import re
import time
import serial
INTERVAL = 1 # check every INTERVAL minutes
serv = 'mail.google.com'
path = '/mail/feed/atom'
auth = base64.encodestring(
'%s:%s'%(raw_input('Username: '),
getpass.getpass()))
def count(data):
matches = re.findall('<fullcount>([0-9]+)</fullcount>', data)
if len(matches) == 0:
print 'Error in parsing feed, check user name and password are correct'
return 0
return int(matches[0])
def getfeed():
print 'Checking...'
conn = httplib.HTTPSConnection(serv)
conn.putrequest('GET', path)
conn.putheader('Authorization', 'Basic %s'%auth)
conn.endheaders()
return conn.getresponse().read()
def writeSer(data):
try:
ser = serial.Serial('COM6')
ser.write(data)
except serial.serialutil.SerialException:
print 'Error writing to serial device'
raise
last_check = time.time() - INTERVAL*60 # subtract so that we check first time
while True:
if time.time() - last_check < INTERVAL*60:
continue
msgs = count(getfeed())
print type(msgs)
print msgs,'mails'
writeSer(str(msgs))
LED Matrix
//code courtesy of Hari Wiguna
//http://g33k.blogspot.com/
//-- Columns (Negative Cathodes) --
int latchPin1 = 2; //Arduino pin connected to Green Latch 12 ST_CP / RCK of 74HC595
int clockPin1 = 3; //Arduino pin connected to Yellow Clock 11 SH_CP / SCK of 74HC595
int dataPin1 = 4; //Arduino pin connected to Blue Data 14 DS / SI of 74HC595
//-- Rows (Positive Anodes) --
int latchPin2 = 5; //Arduino pinn connected to Green Latch 12 ST_CP / RCK of 74HC595
int clockPin2 = 6; //Arduino pin connected to Yellow Clock 11 SH_CP / SCK of 74HC595
int dataPin2 = 7; //Arduino pin connected to Blue Data 14 DS / SI of 74HC595
//=== B I T M A P ===
//Bits in this array represents one LED of the matrix
// 8 is # of rows, 7 is # of LED matrix we have
byte bitmap[8][4]; // Change the 7 to however many matrices you want to use.
int numZones = sizeof(bitmap) / 8; // I will refer to each group of 8 columns (represented by one matrix) as a Zone.
int maxZoneIndex = numZones-1;
int numCols = numZones * 8;
//=== F O N T ===
// Font courtesy of aspro648
// http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1203747843/22
// First char is @, next is A, B, etc. Only lower case, no symbols.
// The @ will display as space character.
byte alphabets[][5] = {
{0,0,0,0,0}, //'.' but replaced as 'blank,space'
{1, 6, 8, 48, 64}, //'/'
{62, 69, 73, 81, 62}, //0 - zero
{0, 33, 127, 1, 0}, //1
{49, 67, 69, 73, 49}, //2
{34, 65, 73, 73, 54}, //3
{24, 104, 8, 127, 8}, //4
{114, 73, 73, 73, 70}, //5
{62, 73, 73, 73, 38}, //6
{64, 64, 71, 72, 112}, //7
{54, 73, 73, 73, 54}, //8
{50, 73, 73, 73, 62}, //9
{0, 54, 54, 0, 0}, //:
{0, 53, 54, 0, 0}, //;
{8, 28, 54, 99, 65}, //<
{34, 34, 34, 34, 34}, //=
{65, 99, 54, 28, 8}, //>
{32, 64, 77, 72, 48}, //?
{62, 77, 85, 93, 60}, //@
{31, 36, 68, 36, 31}, //A
{127, 73, 73, 73, 54}, //B
{62, 65, 65, 65, 34}, //C
{127, 65, 65, 34, 28}, //D
{127, 73, 73, 65, 65}, //E
{127, 72, 72, 72, 64}, //F
{62, 65, 65, 69, 38}, //G
{127, 8, 8, 8, 127}, //H
{0, 65, 127, 65, 0}, //I
{2, 1, 1, 1, 126}, //J
{127, 8, 20, 34, 65}, //K
{127, 1, 1, 1, 1}, //L
{127, 32, 16, 32, 127}, //M
{127, 32, 16, 8, 127}, //N
{62, 65, 65, 65, 62}, //O - not zero
{127, 72, 72, 72, 48}, //P
{62, 65, 69, 66, 61}, //Q
{127, 72, 76, 74, 49}, //R
{50, 73, 73, 73, 38}, //S
{64, 64, 127, 64, 64}, //T
{126, 1, 1, 1, 126}, //U
{124, 2, 1, 2, 124}, //V
{126, 1, 6, 1, 126}, //W
{99, 20, 8, 20, 99}, //X
{96, 16, 15, 16, 96}, //Y
{67, 69, 73, 81, 97}, //Z
//=== S E T U P ===
pinMode(latchPin1, OUTPUT);
pinMode(clockPin1, OUTPUT);
pinMode(dataPin1, OUTPUT);
pinMode(latchPin2, OUTPUT);
pinMode(clockPin2, OUTPUT);
pinMode(dataPin2, OUTPUT);
//-- Clear bitmap --
for (int row = 0; row < 8; row++) {
for (int zone = 0; zone <= maxZoneIndex; zone++) {
bitmap[row][zone] = 0;
//=== F U N C T I O N S ===
// This routine takes whatever we've setup in the bitmap array and display it on the matrix
void RefreshDisplay()
int rowbit = 1 << row;
digitalWrite(latchPin2, LOW); //Hold latchPin LOW for as long as we're transmitting data
shiftOut(dataPin2, clockPin2, MSBFIRST, rowbit); //Transmit data
//-- Start sending column bytes --
digitalWrite(latchPin1, LOW); //Hold latchPin LOW for as long as we're transmitting data
//-- Shift out to each matrix (zone is 8 columns represented by one matrix)
for (int zone = maxZoneIndex; zone >= 0; zone--) {
shiftOut(dataPin1, clockPin1, MSBFIRST, bitmap[row][zone]);
//-- Done sending Column bytes, flip both latches at once to eliminate flicker
digitalWrite(latchPin1, HIGH); //Return the latch pin high to signal chip that it no longer needs to listen for information
digitalWrite(latchPin2, HIGH); //Return the latch pin high to signal chip that it no longer needs to listen for information
//-- Wait a little bit to let humans see what we've pushed out onto the matrix --
delayMicroseconds(500);
// Converts row and column to actual bitmap bit and turn it off/on
void Plot(int col, int row, bool isOn)
int zone = col / 8;
int colBitIndex = col % 8;
byte colBit = 1 << colBitIndex;
if (isOn)
bitmap[row][zone] = bitmap[row][zone] | colBit;
bitmap[row][zone] = bitmap[row][zone] & (~colBit);
// Plot each character of the message one column at a time, updated the display, shift bitmap left.
void AlphabetSoup(){
byte email;
if (Serial.available() > 0) {email = Serial.read();}
else {email = 0;}
char msg[6];
sprintf ( msg, "%d mails", email );
for (int charIndex=0; charIndex < (sizeof(msg)-1); charIndex++)
int alphabetIndex = msg[charIndex] - '.'; // The Fonts starts from ascii table of '/' until 'Z'. refer to ascii table here - http://www.asciitable.com
if (alphabetIndex < 0) alphabetIndex=0;
//-- Draw one character of the message --
// Each character is only 5 columns wide, but I loop two more times to create 2 pixel space betwen characters
for (int col = 0; col < 7; col++)
// Set the pixel to what the alphabet say for columns 0 thru 4, but always leave columns 5 and 6 blank.
bool isOn = 0;
if (col<5) isOn = bitRead( alphabets[alphabetIndex][col], 7-row ) == 1;
Plot( numCols-1, row, isOn); // We ALWAYS draw on the rightmost column, the shift loop below will scroll it leftward.
//-- The more times you repeat this loop, the slower it would scroll --
for (int refreshCount=0; refreshCount < 10; refreshCount++)
RefreshDisplay();
//-- Shift the bitmap one column to left --
for (int row=0; row<8; row++)
for (int zone=0; zone < numZones; zone++)
// This right shift would show as a left scroll on display because leftmost column is represented by least significant bit of the byte.
bitmap[row][zone] = bitmap[row][zone] >> 1;
// Roll over lowest bit from the next zone as highest bit of this zone.
if (zone < maxZoneIndex) bitWrite(bitmap[row][zone], 7, bitRead(bitmap[row][zone+1],0));
//=== L O O P ===
AlphabetSoup();
oh,and pardon for the bad english =P
