Good Evening Gentlemen!
My problem is that the arduino restarts when i text the keyword "CHECK STATUS".
Is there something wrong with my string manipulation? And if there is, please tell me what to do.
Thank you! God Bless!
Ill post the code after this, it exceeds the max characters.
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
boolean started=false;
int pinone = 4;
int pintwo = 5;
int pinthree = 6;
int pinfour = 7;
int feedone = 8;
int feedtwo = 9;
int feedthree = 10;
int feedfour = 11;
boolean one = false;
boolean two = false;
boolean three = false;
boolean four = false;
pinMode(pinone, OUTPUT);
pinMode(pintwo, OUTPUT);
pinMode(pinthree, OUTPUT);
pinMode(pinfour, OUTPUT);
pinMode(feedone, INPUT);
pinMode(feedtwo, INPUT);
pinMode(feedthree, INPUT);
pinMode(feedfour, INPUT);
Serial.println("GSM Shield testing.");
if (gsm.begin(9600))
Serial.println("\nstatus=READY");
started=true;
else Serial.println("\nstatus=IDLE");
char position;
char phone_num[20] = {'\0'};
char sms_text[100] = {'\0'};
if (started)
position = sms.IsSMSPresent(SMS_UNREAD);
if (position)
sms.GetSMS(position, phone_num, sms_text, 100);
Serial.println("Data Received");
Serial.println(phone_num);
Serial.println(sms_text);
get_cmd(sms_text);
gsm.SimpleWrite("AT+CMGD=1,4");
Serial.println("SMS DELETED");
clearstring_num(phone_num);
delay(250);
clearstring_txt(sms_text);
delay(250);
void clearstring_num(char *strArray_num)
int j;
for (j = 20; j > 0; j--)
strArray_num[j] = 0x00;
void clearstring_txt(char *strArray_txt)
int j;
for (j = 100; j > 0; j--)
strArray_txt[j] = 0x00;
void get_cmd(char *command)
char sms_ctext[100] = {'\0'};
sprintf(sms_ctext, "%s", command);
int i;
if (strcmp(sms_ctext,"ON 1") == 0 )
if(!one)
i = digitalRead(feedone);
if (i == 0)
digitalWrite(pinone,HIGH);
sms.SendSMS("+639XXXXXXX", "Port One is ON");
Serial.println("Port One is ON");
one = true;
sms.SendSMS("+639XXXXXXX", "Switch ONE is ON, Turn OFF the switch before proceeding.");
else if (strcmp(sms_ctext,"ON 2") == 0 )
if(!two)
i = digitalRead(feedtwo);
if (i == 0)
digitalWrite(pintwo,HIGH);
sms.SendSMS("+639XXXXXXX, "Port Two is ON");
Serial.println("Port Two is ON");
two = true;
sms.SendSMS("+639XXXXXXX", "Switch TWO is ON, Turn OFF the switch before proceeding.");
else if (strcmp(sms_ctext,"ON 3") == 0 )
if(!three)
i = digitalRead(feedthree);
if (i == 0)
digitalWrite(pinthree,HIGH);
sms.SendSMS("+639XXXXXXX", "Port Three is ON");
Serial.println("Port Three is ON");
three = true;
sms.SendSMS("+639XXXXXXX", "Switch THREE is ON, Turn OFF the switch before proceeding.");
else if (strcmp(sms_ctext,"ON 4") == 0 )
if(!four)
i = digitalRead(feedfour);
if (i == 0)
digitalWrite(pinfour, HIGH);
sms.SendSMS("+639XXXXXXX", "Port Four is ON");
Serial.println("Port Four is ON");
four = true;
sms.SendSMS("+639XXXXXXX", "Switch FOUR is ON, Turn OFF the switch before proceeding.");
else if (strcmp(sms_ctext,"OFF 1") == 0 )
if (i == 0)
digitalWrite(pinone,LOW);
sms.SendSMS("+639XXXXXXX", "Port One is OFF");
Serial.println("Port One is Off");
one = false;
else if (strcmp(sms_ctext,"OFF 2") == 0 )
if (i == 0)
digitalWrite(pintwo,LOW);
sms.SendSMS("+639XXXXXXX", "Port Two is OFF");
Serial.println("Port Two is Off");
two = false;
else if (strcmp(sms_ctext,"OFF 3") == 0 )
if (i == 0)
digitalWrite(pinthree,LOW);
sms.SendSMS("+639XXXXXXX", "Port Three is OFF");
Serial.println("Port Three is Off");
three = false;
else if (strcmp(sms_ctext,"OFF 4") == 0 )
if (i == 0)
digitalWrite(pinfour,LOW);
sms.SendSMS("+639XXXXXXX", "Port Four is OFF");
Serial.println("Port Four is Off");
four = false;
else if (strcmp(sms_ctext,"CHECK STATUS") == 0 )
check_status();
else if (strcmp(sms_ctext,"OFF ALL") == 0 )
off_all();
sms.SendSMS("+639XXXXXXX", "Invalid Command or Message Not Read");
Serial.println("Invalid Command/s");
void check_status()
int uno, dos, tres, quatro;
char stat_one[25];
char stat_two[25];
char stat_three[25];
char stat_four[25];
char info[150];
uno = digitalRead(feedone);
switch (uno)
case 0: strcpy(stat_one, "Port One: OFF\n");
strcat(info,stat_one);
case 1: strcpy(stat_one, "Port One: ON\n");
default: break;
dos = digitalRead(feedtwo);
switch (dos)
case 0: strcpy(stat_two, "Port Two: OFF\n");
strcat(info,stat_two);
case 1: strcpy(stat_two, "Port Two: ON\n");
default: break;
tres = digitalRead(feedthree);
delay(250);
switch (tres)
case 0: strcpy(stat_three, "Port Three: OFF\n");
strcat(info,stat_three);
case 1: strcpy(stat_three, "Port Three: ON\n");
default: break;
quatro = digitalRead(feedfour);
switch (quatro)
case 0: strcpy(stat_four, "Port Four: OFF\n");
strcat(info,stat_four);
case 1: strcpy(stat_four, "Port Four: ON\n");
default: break;
sms.SendSMS("+639XXXXXXX", info);
void off_all()
int first;
int second;
int third;
int fourth;
first = digitalRead(feedone);
delay(100);
delay(100);
second = digitalRead(feedtwo);
delay(100);
delay(100);
third = digitalRead(feedthree);
delay(100);
delay(100);
fourth = digitalRead(feedfour);
delay(100);
delay(100);
if ((first == 1)||(second == 1)||(third == 1)||(fourth == 1))
sms.SendSMS("+639XXXXXXX","Please Turn Off All Switches for command to take place.");
digitalWrite(pinone, LOW);
one = false;
digitalWrite(pintwo, LOW);
two = false;
digitalWrite(pinthree, LOW);
three = false;
digitalWrite(pinfour, LOW);
four = false;
sms.SendSMS("+639XXXXXXX","All Ports are now OFF");
Considering check_status() puts another 250 bytes onto the stack, I'm guessing you're running out of memory. Search the forum for "free memory" to check how much memory you have left before you call the function.
Any ways on how can i save RAM?
horikitamaki:
You might try the F() macro like below.
to
sms.SendSMS(F("+639XXXXXXX", "Switch THREE is ON, Turn OFF the switch before proceeding."));
Why do you make a copy of the literal string?
could be:
case 0: strcat(info, "Port One: OFF\n");
That saves 100 bytes there.
Since info contains nothing before you append data to it, there is no reason for info to by 6 times as large as the message to be appended. At most, it needs to be 4 times as large.
Thank you!
By the way, what does this F() do?
Read this Arduino Playground - Memory.
