Alright, enough is enough. I cannot for the love to god get this to work.
I am putting a WiFiShield on top of a Rev2 Uno, which is not normal to begin with, so I jumper the 3.3v to the IOREF like the guide says and I receive the classic "Shield not present".
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
So I look around... apparently others found success with changing the above code with this:
unsigned long start=millis();
while (WiFi.status() == WL_NO_SHIELD)
if ((millis()-start)>30000)
// don't continue:
while(true);
So I then assume its some sort of hardware issue. I check the voltage from the jumper (3.3v -> IOREF) and it clocks at 5V... hmm... thats wrong. So I check the voltage of each pin alone 3.3v clocks in right, 5v clocks in right, IOREF is basically 0, floating voltage. Hmm.. some forum said to jumper the SCL and SDA to two different analog pins. Tried it... didnt work. The L9 light on the Wifi shield is very dim and flickers.. like it doesnt get enough power or some sort of hardware failure.
My question, what else can I do!?
