ive using some SD card with my code but it can't find the index.htm file that i need to use with the server.. i also use the sample sketch but it has the same error in serial monitor and produce a blank page when i browse the Ip address.. what should i do with this,,
ps. the file name in the code and the file name and types of in the SD card was the same. i dont know why its now working even in a default sketch.
What sample sketch?
Use a simple index.htm doc as a test.
<HTML><BODY>
This is a test
</BODY></HTML>
edit: The reason I ask about the example sketch you are trying is most ethernet shield example sketches do not access the SD card. That requires additional code.
the sample sketch i use is this i just found this at this site Arduino SD Card Web Server using Ethernet Shield
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 0, 20); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile;
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
ps. is there any possibility that the sd card is need to be formatted it is in default FAT32.. let me know if i will format it to other parameter
and i also use a simple index.htm webpage
You might want to try a little error checking in that sketch. Send a message to the serial monitor if the sketch is unable to open the index.htm file.
if (webFile) {
webFile.close();
else Serial.println("File open fail");
