Thanks for your help guys, I found a simple sketch and addapt it to my needs timing the pulses and intervals and making a char array to switch low / high.
Riva:
// High/Low microsecond timings, first value is high timing, the rest alternate low/high
const int hlUsTimings[] = {
380,440,700,800,360,440,720,780,380,440,700,800,360,460,700,780,380,440,700,800,360,800,360,460,720,13000};
const int hlUsSize = sizeof(hlUsTimings) / sizeof(hlUsTimings[0]);
const int pinChangeDelay = 0; // Value to subtract from numbers to compensate for instruction timings
const int outPin = 3; // Transmitter output pin
const int ledPin = 4; // LED output pin
pinMode(ledPin,OUTPUT);
pinMode(outPin,OUTPUT);
digitalWrite(outPin,LOW);
delayMicroseconds(13000);
digitalWrite(ledPin,!digitalRead(ledPin));
byte pinState = 0;
noInterrupts();
for (int y = 0; y < hlUsSize; y++){
pinState = !pinState;
digitalWrite(outPin,pinState);
// if (pinState == 0){
// delayMicroseconds(20);
int z = hlUsTimings[y] - pinChangeDelay;
delayMicroseconds(z);
interrupts();
I will try for the other remotes I want to do it, but I think it should work for anything.
Thanks!
