I'm playing around with my first Arduino project, and I've hit a wall. I've spent all day Googling around for tutorials etc but can't seem to find anything solid.
I have two arduino nanos using newsoftserial to communicate via an RF transceiver. The link works great, the problem is data matching.
What I"m trying to do is send a short string of letters/numbers to the receiving Arduino which would then do something if a matching string is received.
The receiving Arduino's debug output is very erratic, someties it matches the two if statements, 90% of the time it does not even though in the output I can see the "sending1" and "sending2" commands. See below the code blocks for some random output.
I suggest you try to fake the receiving end with a terminal program to make sure its sending data correctly, then fake the sending program by typing the data on the terminal.
if you're sending data especially over a radio link, a checksum byte is a good idea. then the receiver can at least have some confidence that it received the data correctly.
//inData[index] = '\0'; // Null terminate the string
Why is this commented out. It is most definitely needed.
You would have much better luck sending strings in packets - with a start of packet marker and an end of packet marker. When the start of packet marker arrives, initialize the array and set a flag, started, to true, and another flag, ended, to false. When additional characters arrive, that are not the end of packet marker, append them to the array, followed by the NULL terminator. When the end of packet marker arrives, set the ended flag to true. Only process data when started and ended are true. When done processing the data, set started and ended to false.
Search the forum for "started && ended" for some code.
Thanks for the comments all, while I waited for responses to this post I tried something new which actually seems to work great. The receiver misses 1 transmission once in a while (rarely) for some reason.
Can someone take a quick look and let me know if this is the best way to do this or maybe provide some tips?
// ARDUINO NANO TRANSMITTER
#include <NewSoftSerial.h>
NewSoftSerial comSerial = NewSoftSerial(4, 5); //rx tx
int counter = 0;
void setup(){
comSerial.begin(9600);
char sending[6] = {0xC8,0xaf,0x32,counter,0x01,0xC8}; // don't know how to convert an int to hex unfortunately
comSerial.print(sending);
delay(100);
counter++;
if(counter == 250) counter = 0;
The char array passed to Serial.print() must be NULL terminated. Yours isn't. The Serial.print() function will continue printing array values beyond the end of your array, until it finds a NULL.
You sent 0xC8, but are checking for 200. Why? Send and check the same values.
The value is stored in binary. The way it is printed, hex, binary, decimal, or some other base, has no relationship to how the value is stored in memory. What is it you think you need to convert to hex?
If 5 out of the 6 bytes you are sending are constant, why do you need to send them?
0xC8 is 200 in DEC so it's checking the same values
I'm not sure why I'm even bothering to transmit in hex values, should all be integers right? That would make a heck of a lot more sense I think.
I'm just testing out the tx / rx, these bytes are going to be dynamically generated.
But, for readability, you should be using 0xC8 on both sides, or 200 on both sides.
Hex values ARE integers. So are binary values, octal values, and decimal values. I think that what you mean is that the values should all be decimal. If that is the case, the answer is the infamous "it depends". There are cases where a hex value makes more sense than a decimal value. I don't think that holds true, here, though.
