ok, so I have made a few posts about this projects before, but it has been all over the place, and I need to consolidate it into one forum. My project is and RFID attendance system using the uno, ethernet shield, and the Rc522 reader. this hardware takes the card number, validates it and sends it as allowed or not allowed with the timestamp and the card number to a pushingbox api that then executes a google script which sends the data to a google spreadsheet. I know, the project is very complicated for someone who is a beginner like myself. I have been working on this for weeks in class now, and it hasn't been working, so I made posts and eventually got to the point where it would read my valid card number, say valid person, then connect in the arduino serial monitor thing. now it just gets stuck on connecting, and wont scan at all and I dont know why. I have not changed anything so if someone could help me that would be fantastic. i am freaking out about this because i have a project showcase monday and it is not working now.
this is my arduino code from when I believe I had it kind of working
/* Arduino Code which sends data to google spreadsheet */
#include<SPI.h>
#include<MFRC522.h>
#include <Ethernet.h>
#define SS_PIN 4 //FOR RFID SS PIN BECASUSE WE ARE USING BOTH ETHERNET SHIELD AND RS-522
#define RST_PIN 9
#define No_Of_Card 3
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "api.pushingbox.com"; //YOUR SERVER
IPAddress ip(*i have my ip here*);
EthernetClient client;
MFRC522 rfid(SS_PIN,RST_PIN);
MFRC522::MIFARE_Key key;
byte id[No_Of_Card][4]={
{204,389,56,51}, //RFID NO-1
{3010,9,31,52}, //RFID NO-2
{142,76,58,42} //RFID NO-3
byte id_temp[0][0];
byte i;
int j=0;
// the setup function runs once when you press reset or power the board
void setup(){
SPI.begin();
rfid.PCD_Init();
for(byte i=0;i<6;i++)
key.keyByte[i]=0xFF;
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Ethernet.begin(mac, ip);
Serial.println("connecting...");
// the loop function runs over and over again forever
void loop(){
int m=0;
if(!rfid.PICC_IsNewCardPresent())
return;
if(!rfid.PICC_ReadCardSerial())
return;
for(i=0;i<3;i++)
id_temp[0][i]=rfid.uid.uidByte[i];
delay(50);
for(i=0;i<No_Of_Card;i++)
if(id[i][0]==id_temp[0][0]) {
Serial.print("your card no :");
for(int s=0;s<3;s++)
Serial.print(rfid.uid.uidByte[s]);
Serial.print(" ");
Serial.println("\nValid Person");
Sending_To_spreadsheet();
j=0;
rfid.PICC_HaltA(); rfid.PCD_StopCrypto1(); return;
else if(id[i][1]==id_temp[0][1]) {
Serial.print(" ");
j=0;
else if(id[i][2]==id_temp[0][2]) {
Serial.print(" ");
j=0;
else if(id[i][3]==id_temp[0][3])
Serial.print(" ");
j=0;
{j++;
for(j=0;j>3;j++)
Serial.println("Not a valid Person");
j=0;
// Halt PICC
rfid.PICC_HaltA();
// Stop encryption on PCD
void Sending_To_spreadsheet() //CONNECTING WITH MYSQL
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.print("GET /pushingbox?devid=v4C30CA17D5F64E2&allowed_members="); //YOUR URL
if(j!=No_Of_Card)
client.print('1');
// Serial.print('1');
client.print('0');
client.print("&Member_ID=");
for(int s=0;s<4;s++)
client.print(rfid.uid.uidByte[s]);
client.print(" "); //SPACE BEFORE HTTP/1.1
client.print("HTTP/1.1");
client.println();
client.println("Host: api.pushingbox.com");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
this is the google script code if this helps
function doGet(e) {
Logger.log( JSON.stringify(e) );
var result = 'Ok';
if (e.parameter == undefined) {
result = 'No Parameters';
else {
var id = '1mu_ae80OFd4kztw5x-vqOcGQvdpwBR2znduJqMsmms0'; // Spreadsheet ID
var sheet = SpreadsheetApp.openById(id).getActiveSheet();
var newRow = sheet.getLastRow() + 1;
var rfidData = [];
rfidData[0] = new Date();
for (var param in e.parameter) {
Logger.log('In for loop, param='+param);
var value = stripQuotes(e.parameter[param]);
switch (param) {
case 'allowed_members': //Parameter
rfidData[1] = value; //Value in column B
case 'Member_ID':
rfidData[2] = value;
default:
result = "Wrong parameter";
Logger.log(JSON.stringify(rfidData));
// Write new row below
var newRange = sheet.getRange(newRow, 1, 1, rfidData.length);
newRange.setValues([rfidData]);
// Return result of operation
return ContentService.createTextOutput(result);
* Remove leading and trailing single or double quotes
function stripQuotes( value ) {
return value.replace(/^["']|['"]$/g, "");
/* most of the code is originally from embedotronic technologies so thank you*/
