hi
i am using this code to make an rfid lock:
int val = 0;
char code[10];
int bytesread = 0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW); // Activate the RFID reader
if(Serial.available() > 0) { // if data available from reader
if((val = Serial.read()) == 10) { // check for header
bytesread = 0;
while(bytesread<10) { // read 10 digit code
if( Serial.available() > 0) {
val = Serial.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // if 10 digit read is complete
Serial.print("TAG code is: "); // possibly a good TAG
Serial.println(code); // print the TAG code
bytesread = 0;
digitalWrite(2, HIGH); // deactivate the RFID reader for a moment so it will not flood
delay(1500); // wait for a bit
where do i put the command for the servo, and how do i get the program to run the servo only when a certain code is detected?
PLEASE HELP!!
thanks
