arduino RGB led strip connection
hi,
i want to connect RGB led strip to arduino to control it. The strip contains 5 or 10 wires. How can i connect it to the board.
to controle the strip i need a program also, how can i start ?
thanks in adv....
Please don't cross-post.
Do you have a datasheet for the RGB strip ?
Usually they just have 4 wires, so "5 or 10 wires" sounds a bit strange.
yes it is having 4 wires only.
one way to do it is described on this page (scroll down a bit):
http://genericnerd.blogspot.com/search/label/LED
I have done it the same way and it works.
In stead of the ULN2003 IC you could use 3 transistors, but using the 2003 makes it easy to wire.
Edit:
You dont need the resistors and the stuff at the bottom of the diagram, but you must connect Arduinos ground to pin 8 of the 2003 IC
