I am trying to use the "3 Axis Encoder Counter Arduino Shield" by robogaia and am confused on how to make the encoder value reset to zero when the index or 'Z channel' is enabled. I have an encoder with A,B, and Z channels and want to reset the count after every revolution(the Z channel will only activate once per revolution). I will post my code below, what I have figured out is how to reset the encoder value to zero with the reset() function, but cannot figure out how to do this only when the z channel is HIGH (thus resetting it after each revolution). Any help would be helpful, thanks!
//Robogaia.com
// the sensor communicates using SPI, so include the library:
#include <SPI.h>
#define CNTR B00100000
#define CLR B00000000
int chipSelectPin1=10;
int chipSelectPin2=9;
int chipSelectPin3=8;
//end calibration values
pinMode(chipSelectPin1, OUTPUT);
pinMode(chipSelectPin2, OUTPUT);
pinMode(chipSelectPin3, OUTPUT);
digitalWrite(chipSelectPin1, HIGH);
digitalWrite(chipSelectPin2, HIGH);
digitalWrite(chipSelectPin3, HIGH);
LS7366_Init();
delay(100);
long encoder1Value;
long encoder2Value;
long encoder3Value;
encoder1Value = getEncoderValue(1);
Serial.print("Encoder X= ");
Serial.print(encoder1Value);
encoder2Value = getEncoderValue(2);
Serial.print(" Encoder Y= ");
Serial.print(encoder2Value);
encoder3Value = getEncoderValue(3);
Serial.print(" Encoder Z= ");
Serial.print(encoder3Value);
Serial.print("\r\n");
resetEncoder(1);
delay(100);
}//end loop
void resetEncoder(int encoder)
selectEncoder(encoder);
SPI.transfer(CLR | CNTR);
deselectEncoder(encoder);
} //end func
long getEncoderValue(int encoder)
unsigned int count1Value, count2Value, count3Value, count4Value;
long result;
SPI.transfer(0x60); // Request count
count1Value = SPI.transfer(0x00); // Read highest order byte
count2Value = SPI.transfer(0x00);
count3Value = SPI.transfer(0x00);
count4Value = SPI.transfer(0x00); // Read lowest order byte
result= ((long)count1Value<<24) + ((long)count2Value<<16) + ((long)count3Value<<8) + (long)count4Value;
return result;
}//end func
void selectEncoder(int encoder)
switch(encoder)
case 1:
digitalWrite(chipSelectPin1,LOW);
case 2:
digitalWrite(chipSelectPin2,LOW);
case 3:
digitalWrite(chipSelectPin3,LOW);
}//end switch
}//end func
void deselectEncoder(int encoder)
switch(encoder)
case 1:
digitalWrite(chipSelectPin1,HIGH);
case 2:
digitalWrite(chipSelectPin2,HIGH);
case 3:
digitalWrite(chipSelectPin3,HIGH);
}//end switch
}//end func
// LS7366 Initialization and configuration
void LS7366_Init(void)
// SPI initialization
SPI.begin();
//SPI.setClockDivider(SPI_CLOCK_DIV16); // SPI at 1Mhz (on 16Mhz clock)
delay(10);
SPI.transfer(0x88);
SPI.transfer(0x03);
SPI.transfer(0x88);
SPI.transfer(0x03);
SPI.transfer(0x88);
SPI.transfer(0x03);
}//end func
