This is my Code for my Project how i have it set up right now!
#include <Servo.h>
Servo s1; //base rotation
Servo s2; //lower arm joint
Servo s3; //upper arm joint
Servo s4; //upper arm rotation
Servo s5; //wrist
Servo s6; //hand rotation
int modeSwitchPin = 2;
//servo pins
int sp1 = 3;
int sp2 = 5;
int sp3 = 6;
int sp4 = 9;
int sp5 = 10;
int sp6 = 11;
//pot pins
int pp1 = A0;
int pp2 = A1;
int pp3 = A2;
int pp4 = A3;
int pp5 = A4;
int pp6 = A5;
int lastPos[7] = {0, 0, 0, 0, 0, 0, 0};
// x, 1, 2, 3, 4, 5, 6 you must set these to your system..
int calibration[7] = {0, 0, -20, -12, 0, 0, 0};
int neutralPos[7] = {0,93,121,37,80,86,80};
bool moved = false;
bool debug = false;
bool inJoyStickMode = true;
void gotoNeutralPos(){
for(int i=1; i<=6; i++) doMove(i, neutralPos*,0);*
Serial.begin(115200);*
s1.attach(sp1);*
s2.attach(sp2);*
s3.attach(sp3);*
s4.attach(sp4);*
s5.attach(sp5);*
s6.attach(sp6);*
pinMode(pp1, INPUT);*
pinMode(pp2, INPUT);*
pinMode(pp3, INPUT);*
pinMode(pp4, INPUT);*
pinMode(pp5, INPUT);*
pinMode(pp6, INPUT);*
pinMode(modeSwitchPin, INPUT_PULLUP); //defaults to joystick mode..*
if(digitalRead(modeSwitchPin) == HIGH){*
inJoyStickMode = true;*
JoyStickMode();*
else{*
if(inJoyStickMode){*
inJoyStickMode = false;*
gotoNeutralPos();*
SerialControlMode();*
void JoyStickMode(){
moved = false;*
int raw1 = analogRead(pp1);*
int raw2 = analogRead(pp2);*
int raw3 = analogRead(pp3);*
int raw4 = analogRead(pp4);*
int raw5 = analogRead(pp5);*
int raw6 = analogRead(pp6);*
int pos1 = map(raw1, 0, 1023, 0, 180);*
int pos2 = map(raw2, 0, 1023, 180, 0); //note i accidently swapped which side my +/- were on so I have to swap the mapping..(arm was acting in reverse of my motion)*
int pos3 = map(raw3, 0, 1023, 0, 180);*
int pos4 = map(raw4, 0, 1023, 0, 180); //not implemented in joystick yet*
int pos5 = map(raw5, 0, 1023, 0, 180);*
int pos6 = map(raw6, 0, 1023, 0, 180); //not implemented in joystick yet*
if(abs(pos1 - lastPos[1]) > 2) doMove(1, pos1, raw1);*
if(abs(pos2 - lastPos[2]) > 2) doMove(2, pos2, raw2);*
if(abs(pos3 - lastPos[3]) > 2) doMove(3, pos3, raw3);*
if(abs(pos4 - lastPos[4]) > 2) doMove(4, pos4, raw4);*
if(abs(pos5 - lastPos[5]) > 2) doMove(5, pos5, raw5);*
if(abs(pos6 - lastPos[6]) > 2) doMove(6, pos6, raw6);*
if(moved){*
if(debug)*
Serial.println();*
else{*
Serial.print(pos1);Serial.print(',');*
Serial.print(pos2);Serial.print(',');*
Serial.print(pos3);Serial.print(',');*
Serial.print(pos4);Serial.print(',');*
Serial.print(pos5);Serial.print(',');*
Serial.print(pos6); *
Serial.println();*
void SerialControlMode(){
String n;*
_ Servo* s = 0;_
int i=1;*
int pos[7] = {0, 0, 0, 0, 0, 0, 0};*
char tmp[100];*
_ char *t = &tmp[0];_
//expected input 6 csv numbers for servo positions \n*
//0,0,0,0,0,0\n*
while(!Serial.available()){*
delay(1);*
if(digitalRead(modeSwitchPin) == HIGH) return; //they entered joystick mode..*
n = Serial.readStringUntil('\n');*
if(n.length() >= 100){*
Serial.println("Invalid to long!");*
return;*
strcpy(tmp,n.c_str());*
while(i < 7){*
_ pos = atoi(t);_
* i++;*
* if(i!=7){*
_ while(t != ','){
if(t == 0){i=7; break;}_
_ t++;_
* t++;*
* if(i!=7){*
* Serial.print("Invalid command string i=");*
* Serial.println(i);*
* Serial.println();*
* return;*
* if(debug){*
* Serial.print("Parsed input: ");*
* for(i=1; i<=6; i++){*
_ Serial.print(pos*);
Serial.print( (i==6 ? '\n' : ',' ) );
bool isEmpty = true;
if(pos != 0){ isEmpty = false; break; }
if(!isEmpty){
for(i=1; i<=6; i++){_
if( pos != lastPos _) doMove(i,pos,0);
Serial.println("OK");
}_
_Servo getServo(int index){
* switch(index){
case 1: return &s1;
case 2: return &s2;
case 3: return &s3;
case 4: return &s4;
case 5: return &s5;
case 6: return &s6;
return 0;
void doMove(int index, int pos, int raw){_
_ Servo* s = getServo(index);
* if(s==0) return;
lastPos[index] = pos;
if(debug) dbg(index,raw,pos);
s->write(pos + calibration[index]);
moved = true;
void dbg(int index, int raw, int pos){_
* Serial.print(index);*
* Serial.print(") ");*
* Serial.print("Raw: ");*
* Serial.print(raw);*
* Serial.print(" Mapped: "); *
* Serial.println(pos);*
bool debug = true;
* Serial.begin(115200);*
