Arduino Robot Car (limit switch)
I am working on a robot car project which will calculate distance and move to the longest path every 1 second and some limit switches were used to prevent robot from getting stuck. The function of limit switch in this project is when the limit switch is triggered it will stop and move in opposite direction. The codes that I written is workable but there is a slight error in it. While moving forward/backward the limit switch were triggered suddenly and the robot was unable to run the function for the limit switch, the motors will continue to rotate until the loop is finished then only it will run the function of the limit switch. Any solution for this? Thanks. :grin:
Below shows the written codes:
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 250
#define MAX_SPEED 150 // sets speed of DC  motors
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
Servo myservo;
int speedSet = 0;//
int distance = 100;
int del = 0;
byte switch1 = A4, switch2 = A3;
  pinMode(switch1, INPUT_PULLUP);
  pinMode(switch2, INPUT_PULLUP);
  myservo.attach(10);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  int distanceR = 0;
  int distanceL = 0;
  int distance = readPing();
  delay(50);
  myservo.write(90);
  delay(200);
  if (digitalRead(switch1) == LOW) {//Front limit switch
    moveStop();
    moveBackward();
    delay(200);
    moveStop();
    delay(200);
  else if (digitalRead(switch2) == LOW) {//Rear limit switch
    moveStop();
    moveForward();
    delay(100);
    moveStop();
    delay(200);
  else{
  if (distance > 20)//different delay were used to prevent collision
    if (distance >= 150)
      del = 900;
    else if (distance < 150 && distance >= 80)
      del = 600;
    else if (distance < 80 && distance >= 40)
      del = 300;
    else if (distance < 40)
      del = 150;
    moveForward();
    delay(del);
    moveStop();
    delay(200);
    distance = lookFront();
    delay(200);
    distanceR = lookRight();
    delay(200);
    distanceL = lookLeft();
    delay(200);
    if (distance >= distanceR)//Compare for the longest distance
      if (distance >= distanceL)
        moveStop();
        delay(100);
        turnLeft();
        moveStop();
        delay(100);
    else if (distanceR > distance)
      if (distanceR >= distanceL)
        turnRight();
        moveStop();
        delay(100);
        turnLeft();
        moveStop();
        delay(100);
  else {//obstcale in front lesser than 20cm
    moveStop();
    delay(100);
    moveBackward();
    delay(200);
    moveStop();
    delay(200);
    delay(200);
    delay(200);
    if (distanceL <= 20 && distanceR <= 20 )//compare left and right
      turnAround();//turn 180 degree when left and right were lesser than 20cm
      moveStop();
      delay(100);
    else if (distanceL > distanceR)
      turnLeft();
      moveStop();
      delay(100);
    else if (distanceR > distanceL)
      turnRight();
      moveStop();
      delay(100);
int lookFront()
  delay(100);
  return distance;
  delay(100);
int lookRight()
  myservo.write(10);
  delay(100);
  myservo.write(90);
  return distance;
  delay(100);
int lookLeft()
  myservo.write(170);
  delay(100);
  myservo.write(90);
  return distance;
  delay(100);
int readPing() {
  delay(70);
  int cm = sonar.ping_cm();
  if (cm == 0)
    cm = 250;
  return cm;
void moveStop() {
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
void moveForward() {
  motor1.run(FORWARD);
  motor2.run(FORWARD);
  motor3.run(FORWARD);
  motor4.run(FORWARD);
  for (speedSet = 0; speedSet < MAX_SPEED; speedSet += 2) // slowly bring the speed up to avoid loading down the batteries too quickly
    motor1.setSpeed(speedSet);
    motor2.setSpeed(speedSet);
    motor3.setSpeed(speedSet);
    motor4.setSpeed(speedSet);
    delay(5);
void moveBackward() {
  motor1.run(BACKWARD);
  motor2.run(BACKWARD);
  motor3.run(BACKWARD);
  motor4.run(BACKWARD);
    delay(5);
void turnRight() {
  delay(325);
  delay(100);
void turnLeft() {
  delay(325);
  delay(100);
void turnAround() {
  delay(650);
Please post the file here rather than attaching it
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
If you get errors when compiling please copy them from the IDE using the "Copy error messages" button and paste the clipboard here in code tags
Hi, thanks for the info. There isn't any error when compiling. The problem here is there is a slight difference with the output expected. The expected output is the program will run the function of the limit switch immediately when it's triggered but the output now is the function will run only when the loop is finished.
Thanks for posting your code but did you forget to use code tags and where is the rest of the code ?
