(arduino robot) Pleaz read it
i make self parking car with arduino robot. but how can the robot drive with 45 degrees???. i have this command " Robot.motorsWrite(255,255); "
You haven't provided anywhere near enough information to provide an answer
Please read and follow the directions in the "How to use this forum" post.
Do not cross post...other copy deleted.
AWOL:
You haven’t provided anywhere near enough information to provide an answer
It’s worse than that Jim! :astonished:
Or not Jim, but - pleas in subject headings tend to make it far less likely for people to offer assistance, even if the actual requests were themselves coherent.
Replace the 255 with 45, and you go from 255 degrees to 45 degrees.
Thank you for ur Answer and sorry for my question wich is so short and mybe is not clear. Arduino robot has just 2 wheels and is take just Robot.motorsWrite(255,255); or Robot.motorsStop;
as example:
#include <ArduinoRobot.h>
#include <Wire.h>
// initialize the robot
Robot.begin();
Robot.motorsWrite(255, 255); // move forward
delay(2000);
Robot.motorsStop(); // fast stop
Robot.motorsWrite(-255, -255); // backward
Robot.motorsWrite(0, 0); // slow stop
Robot.motorsWrite(-255, 255); // turn left
delay(2000);
Robot.motorsWrite(255, -255); // turn right
delay(2000);
but i want the the robot reserves with 45 degrees .
can u help me?
What have you tried/
Paul
ahmed-a91:
can u help me?
Not before you can explain what this is supposed to mean.
when i write " Robot.motorsWrite(-255, 255); " my robot would rotate to right. the problem i need that Robot does not rotate rather riserve with with 45 degree.
here is my full code
and plz if you know why my code doesn’t work exactly , plz tell me.
#include<ArduinoRobot.h>
#include <Wire.h>
#define minimum_CarW 20 // carwidth
#define minimum_CarL 20 // carlength
#define direkt 180
byte park_status = 0;
int sensRight_Front;
int sensRight_Back;
int sensFront;
int sensBack;
int compass1;
void motor_Forward() {
void motor_Back() {
void motor_TurnR() {
void motor_TurnL() {
bool parking_Place_Control()
sensFront = Robot.analogRead(M2);
sensRight_Front = Robot.analogRead(M1);
sensRight_Back = Robot.analogRead(M7);
if ( (sensRight_Front < minimum_CarW) & (sensRight_Back < minimum_CarW) & (park_status == 0))
motor_Forward();
park_status = 1;
Serial.println(park_status);
Serial.println(“Suchen nahc Parkplatz”);
if ((sensRight_Front > minimum_CarW) & (sensRight_Back > minimum_CarW) & (park_status == 1))
motor_Forward();
park_status = 2;
Serial.println(" Parkplatz gefunden!!");
if ((sensRight_Front < minimum_CarW) & (sensRight_Back < minimum_CarW) & (park_status == 2))
// Park_prozessor
park_status = 3;
Serial.println(“Parken Anfangen”);
return park_status ;
void park_prozessor() // das Auto fängt an zu parken nach dem Parkplatz gefunden wurde
parking_Place_Control();
if (park_status == 3)
Robot.motorsStop();
delay(400);
park_status = 4;
if (park_status == 4)
motor_Back();
if ((sensRight_Front < minimum_CarW) & (sensRight_Back > minimum_CarW) & (park_status == 4))
Robot.motorsStop();
park_status = 5;
if (park_status == 5)
void motor_TurnR();
int compassValue = Robot.compassRead();
int diff = compassValue - direkt;
if ( diff >= 45 )
Robot.motorsStop();
park_status = 6;
if (park_status == 6)
motor_TurnL();
Serial.println(sensRight_Back);
Serial.println(sensRight_Front);
if ( sensRight_Front == sensRight_Back)
Robot.motorsStop();
park_status = 7;
return sensRight_Front , sensRight_Back;
if (park_status == 7)
sensFront = Robot.analogRead(M1);
sensBack = Robot.analogRead(M6);
if (sensFront == sensBack)
Robot.motorsStop();
park_status = 8;
} else
motor_Forward();
} return sensFront, sensBack;
if (park_status == 8)
Serial.println(“das Auto ist geparkt”);
Robot.begin();
park_prozessor();
Swap the wires of the offending motor.
ahmed-a91:
OK, first things first.
You need to go and read the forum instructions so that you can go back and modify your original posts (not re-post them) - using the “More → Modify” option below the right hand corner of your post - to mark up your code as such using the “</>” icon in the posting window. Just highlight each section of code (or output if you need to post that) from the IDE and click the icon.
In fact, the IDE has a “copy for forum” link to put these markings on a highlighted block for you so you then just paste it here in a posting window. But even before doing that, don’t forget to use the “Auto-Format” (Ctrl-T) option first to make it easy to read. If you do not post it as “code” it can as you now see, be garbled and is always more difficult to read.
It is inappropriate to attach it as a “.ino” file unless it is clearly too long to include in the post proper. People can usually see the mistakes directly and do not want to have to actually load it in their own IDE. And that would also assume they are using a PC and have the IDE running on that PC.
Also tidy up your blank space. Do use blank lines, but only between complete functional blocks.
thank you very much.
i will keep it and fix my post then i will post it in the right dipartment
ahmed-a91:
Which would be a reply to this existing thread.
