I was recently jotting down some ideas for simple GPS navigation, and I planned to do it based on a "direction + deviation" system - sort of like, you tell the entity where to go, and how far it is, and based on its movement, it updates its current position relative to the waypoint until it gets there...
if there is some sort of obstacle, then the entity should know how to get around the object, while, at the same time, keeping in mind the direction it should continue to go in once the obstacle is overcome, this way the entity will always stay on its path, one way or the other...
perhaps its a bad explanation, its like 3 am here, so if you want a more accurate response, let me know (it should also get me thinking on how i will write up my own routing system which i have been planning to do)
I kind-of-sorta understand your explanation, but I get the gist of it. ;D
Can you elaborate, though?
BTW:
I had thought of something kind like your idea:
Program in the waypoint(s)
Boot-up and check location
Orient towards waypoint.
Begin travel.
Use some sort of ultrasonic or infra-red sensor to detect objects.
If an object is in the way, turn left or right (depending) and travel until the obstruction is no longer in the way.
Turn back towards the waypoint, and travel again.
Basically your outline is correct... ofcourse there is also the question of is this on a 2d plain or 3d space (are you doing this on land or is this an aerial type project)...
more specifically, I would utilize a gyro and perhaps some encoders on the wheels (although, i am not sure if that would be as easy as i think)... you give the robot an angle, say 45 degrees.... and as the robot orients itself towards the object, the 45 degrees should go down to 0 - aka, the robot is pointed directly towards the waypoint.... every time the robot needs to turn for whatever reason, this degree value (i call it degree of deviation) increases (or decreases) accordingly....
not to confuse you, so like i said, the outline u wrote up is generally correct....
I would go with my idea for that exact reason - premade gps is for larger scale activity, and im guessing u are not planning to make an autonomous car to drive on highways....
