Arduino Robot
prossimamente sui vostri tavoli... :grin:
--> http://vimeo.com/64253147#
molto prossimamente... :roll_eyes:
Evidentemente servono a questo le lib postate poco fa da leo72...
Il progetto è questo, ma non hanno ancora pubblicato nulla in merito http://complubot.educa.madrid.org/pre/pre.php
PaoloP: prossimamente sui vostri tavoli... :grin:
piuttosto terrorizzato il ragazzino :stuck_out_tongue_closed_eyes: deve averlo visto volare giù un bel po' di volte :D
--> https://github.com/arduino/Arduino/tree/master/hardware/arduino/bootloaders/caterina-Arduino_Robot
Building the bootloader for the Arduino Robot The Arduino Robot has two boards featuring the atmega32U4 processor from Atmel. Each one of them is identified as a different board at the USB level and has a different bootloader.
The Arduino Robot Control board has the USB identifier 0x0038. This is the value configured by default in the Makefile.
The Arduino Robot Motor board has the USB identifier 0x0039. If you want to compile/upload this version of the bootloader, you will have to edit the Makefile, comment away the like dedicated to the PID and uncomment the one that configures such variable accordingly.
The general conditions for using these bootloaders require downloading a specific version of LUFA as explained here:
Download the LUFA-111009 file (http://fourwalledcubicle.com/blog/2011/10/lufa-111009-released/). Extract that file directly to the Caterina-Arduino_Robot bootloader directory. Open a command prompt in the Caterina-Arduino_Robot bootloader directory. Type 'make'. Enjoy! Programming the bootloader for one of the Arduino Robot boards 1. Open a command prompt in the Caterina-Arduino_Robot folder. 2. Connect your programmer- use a 2x3 .1" header, pressed against the programming vias. 3. Edit the make file for it to include the right programmer (e.g. in my lab I have AVRMKII and USBTINY ISP) 4. Type 'make program' into the command prompt.
Differences between this bootoloader and the standard one for Leonardo boards This bootloader is different from the one on the standard Leonardo boards. To enter the bootloader, you need to double click the reset button. You need to click twice in less that 3/4 of a second (easy uh?). This bootloader, designed in the first place for the LilypadUSB, seems to be optimal for situations when users are e.g. using their robots in soccer competitions where they make direct manipulation of the board as it runs.
Quindi il robot è formato da due board ognuna con un 32U4 a bordo.
[quote author=Michele Menniti link=topic=166452.msg1241181#msg1241181 date=1368644100]
piuttosto terrorizzato il ragazzino :stuck_out_tongue_closed_eyes: deve averlo visto volare giù un bel po' di volte :D [/quote] stessa cosa che ho detto nell'altro topic aahahahaha a quanto pare tutta quella velocità in caso di fail è compromettente :stuck_out_tongue_closed_eyes:
Eh, no, altro che line follower ... con tutta la tecnologia che avete a disposizione, mi dovete replicare almeno uno di questi ... :P :D
http://www.youtube.com/watch?v=B_jllEvrOZQ
tutto qui? un bambolotto con dentro un registratore pilotato da un pulsante nascosto nell'asticella del microfono? meglio il line follower a "caduta libera" :stuck_out_tongue_closed_eyes: :stuck_out_tongue_closed_eyes:
ROTFL XD XD XD
E' uscito.
PaoloP: E' uscito.
... dal tavolo ? ...
(scusa, non ho resistito :P XD XD XD)
Etemenanki:
PaoloP: E' uscito.
lo dicevo io :stuck_out_tongue_closed_eyes:
Paolo, ma quanto costa e dove si compra?
Domanda generale: se e quando sarà vorrei finalmente iniziare a fare un po' di robotica a scopo didattico via via più complessa. Cosa mi consigliereste?
So you want to buy an Arduino Robot?
Thanks for your interest in the Arduino Robot! We’re super excited to get it to you.
The Robot will be sold in the Maker Shed at Maker Faire San Mateo (May 17-19).
For those of you unable to make it to Maker Faire, don’t fret! The Robot will be sold online through the Arduino store and our distributors starting early July.
Guglielmo
P.S. : Preso dal sito ufficiale
Forse qui c'è la risposta: http://www.engadget.com/2013/05/19/arduino-robot-launches-at-maker-faire-we-go-hands-on-video/?utm_medium=feed&utm_source=Feed_Classic&utm_campaign=Engadget
Essendo messo male a tempo, ovviamente ho chiesto a chi aveva postato la nitizia certo che ne sapesse di più, senza stare a fare ricerche, visto che non lo devo comprare stanotte, ma tanto prima di luglio non se ne parla, meglio così, forse agosto sarà il mese buono per robottare. Grazie ad entrambi!
Uhm ... secondo me, se cominciate a sperimentare con arduino robot, a forza di modifiche lo tirate fuori cosi
:P :P :P XD XD XD
certo, ma valli a fare gli occhi rossi....
[quote author=Michele Menniti link=topic=166452.msg1246622#msg1246622 date=1369062749] certo, ma valli a fare gli occhi rossi.... [/quote]
Dipende da quanto lontano vuoi che li vedano ... pochi metri http://www.ebay.com/itm/10W-10Watt-Red-High-Power-LED-Light-Lamp-for-Plant-Grow-Growth-630nm-500LM-DIY-/380591901156?pt=LH_DefaultDomain_0&hash=item589d0b89e4 o qualche centinaio http://www.ebay.com/itm/100W-Watt-Red-High-Power-LED-Light-Lamp-Plant-Grow-Growth-630nm-5000LM-18V-DIY-/160985047499?pt=LH_DefaultDomain_0&hash=item257b74e1cb
:P XD
XD XD
[quote author=Michele Menniti link=topic=166452.msg1245751#msg1245751 date=1368994281] Essendo messo male a tempo, ovviamente ho chiesto a chi aveva postato la nitizia certo che ne sapesse di più, senza stare a fare ricerche, visto che non lo devo comprare stanotte, ma tanto prima di luglio non se ne parla, meglio così, forse agosto sarà il mese buono per robottare. Grazie ad entrambi! [/quote]
Ero fuori per diletto. Sono rientrato da poco. Ho messo la notizia ma poi non sono più riuscito a loggarmi sul forum dal mio scarso cellulare. Perdono! :( :cold_sweat:
