There is no forum category for the Arduino Robot under Products. Should we post questions of the robot here instead?
(deleted)
I have a lot of questions right now:
1: There is a piece of paper with robot, which should be attached to the bottom of it. But there is no description on how to best do this?
2: The solution of having 4 contact points to the floor makes the robot getting stuck on even a slightly uneven floor. My workaround is to remove the front caster, but I would like to find a nicer solution like rising the casters slightly.
3: There are a number of mounting holes for components on the upper circuit board. It looks like they are for some kind of sensors, but I can't find any description on how they are intended to be used.
4: The table on the product page of the available pins is slightly hard to read for a beginner. I would like to add a normal servo to the robot, but it is not straightforward to see which pins I can use for this. Especially as there are even question-marks in the table! And no documentation of what PWM8/PWM16/PWN10 stands for. Or what the Arduino Robot Control and Register columns are related to. Also the relationship between the Arduino and the connectors around the perimeter seems to be less than well documented.
