Arduino RoyalTek GPS shield REB-4216
I'm using RoyalTek GPS shield on Arduino mega. This is the source for the code (Internet of Things: GPS Location Sensing with the Arduino Mega) at the first day it worked but the next day it stopped sending information just in output writes 'starting' then no data. What can be the reason for this issue?
#include "TinyGPS.h"
TinyGPS gps;
#define GPS_TX_DIGITAL_OUT_PIN 5
#define GPS_RX_DIGITAL_OUT_PIN 6
long startMillis;
long secondsToFirstLocation = 0;
#define DEBUG
float latitude = 0.0;
float longitude = 0.0;
#ifdef DEBUG
Serial.begin(19200);
#endif
// Serial1 is GPS
Serial1.begin(9600);
// prevent controller pins 5 and 6 from interfering with the comms from GPS
pinMode(GPS_TX_DIGITAL_OUT_PIN, INPUT);
pinMode(GPS_RX_DIGITAL_OUT_PIN, INPUT);
startMillis = millis();
Serial.println("Starting");
readLocation();
void readLocation(){
bool newData = false;
unsigned long chars = 0;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (Serial1.available())
int c = Serial1.read();
// Serial.print((char)c); // if you uncomment this you will see the raw data from the GPS
++chars;
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
// we have a location fix so output the lat / long and time to acquire
if(secondsToFirstLocation == 0){
secondsToFirstLocation = (millis() - startMillis) / 1000;
Serial.print("Acquired in:");
Serial.print(secondsToFirstLocation);
Serial.println("s");
unsigned long age;
gps.f_get_position(&latitude, &longitude, &age);
latitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : latitude;
longitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : longitude;
Serial.print("Location: ");
Serial.print(latitude, 6);
Serial.print(" , ");
Serial.print(longitude, 6);
Serial.println("");
if (chars == 0){
// if you haven't got any chars then likely a wiring issue
Serial.println("Check wiring");
else if(secondsToFirstLocation == 0){
// still working
First: Edit you post and put code tags around the complete code!
Second: Post a link to the hardware product you're actually using!
The only RoyalTek GPS shield I found isn't Mega compatible so cannot be wired directly to use Serial1 on the Mega. Post your wiring!
