Arduino rp2040 connect uploads once from arduino-cli then never again
I've been using an arduino rp2040 connect from arduino-cli and it was fine uploading. I upgraded the libraries:
arduino-cli lib upgrade
and now upload fails every time:
arduino-cli upload --port /dev/ttyACM0 --fqbn arduino:mbed_nano:nanorp2040connect WiFi
Failed uploading: uploading error: exit status 1
I tried upgrading the firmware:
./arduino-fwuploader firmware flash -b arduino:mbed_nano:nanorp2040connect -a /dev/ttyACM0 -m NINA@1.5.0
but what happened isn't documented. I just get a load of these then nothing:
rp2040load 1.0.1 - compiled with go1.15.8
which is the same as when the board is unplugged. So it looks like arduino-cli can no longer connect to the board.
The board is listed and I can upload from the Arduino IDE but arduino-cli upload is broken as is the firmware updater.
Double tapping the reset button does nothing.
I unplugged the board, then plugged it back in and re-ran the firmware updater and it said:
==== AUTHENTICATING FOR org.freedesktop.udisks2.filesystem-mount ===
Authentication is required to mount RPI RP2 (/dev/sdc1)
Authenticating as: ,,, (pi)
None of the above is documented.
Would upgrading libraries break everything?
I was curious about the board definition and noticed there is now another one:
rp2040:rp2040:arduino_nano_connect
using that one solved the problem. Once. The second upload failed with:
Resetting /dev/ttyACM0
Converting to uf2, output size: 140288, start address: 0x2000
Scanning for RP2040 devices
No drive to deploy.
so I double tapped the reset button and the upload worked again:
Password:
==== AUTHENTICATION COMPLETE ===
Flashing /media/pi/RPI-RP2 (RPI-RP2)
Wrote 140288 bytes to /media/pi/RPI-RP2/NEW.UF2
which matches the output from the IDE. It seems the board had changed at some point. The double tap on the reset button doesn't work for the "arduino:mbed_nano:nanorp2040connect" board.
The behaviour is inconsistent as "rp2040:rp2040:arduino_nano_connect" seems to work most of the time:
upload --port /dev/ttyACM0 --fqbn rp2040:rp2040:arduino_nano_connect Blink
using sudo with the firmware upater solves that issue, eventually.
